PIAA 520 install question
Discussion in 'Lighting' started by Icepuck72, Jan 26, 2012.
  1. Jan 26, 2012 at 5:07 AM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    For your install....what power source did you connect to for you switch?
    Everything else is pretty simple it looks.
  2. Jan 26, 2012 at 5:22 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I tapped into the green wire going into the parking lamp. I know that you are "only supposed to wire them to come on with high beams", but i feel i am responsible enough to know not to drive around town with them on. so now i can run them with my lowbeams, high beams, or just on their own.
  3. Jan 26, 2012 at 5:31 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    thanks...so you just used that red splicer/crimp they sent?
    I just read also where someone tapped into any fuse in their fuse box inside the cab (under the dash)
  4. Jan 26, 2012 at 5:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'd want to make sure it's a fuse that is only hot when the ignition is on if you go that route. The switch itself doesn't have much draw, make sure the lights have a more potent power source.
  5. Jan 26, 2012 at 5:49 AM
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    For my PIAA 540 switch, I just used an add-a-circuit and tapped into an empty fuse slot under the dash. If you remove the coin holder, there's an empty slot next to IGN 2 10A and it only draws power when the ignition is on.
  6. Jan 26, 2012 at 5:51 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Thanks...I am just going to wire directly to the battery....
  7. Jan 26, 2012 at 5:53 AM
    TacoFMS
    Justin
    Louisa County, VA
    if you do that then your lights will be "always hot" and if you ever forget them on consider your battery dead.
  8. Jan 26, 2012 at 5:55 AM
    Pugga
    Massachusetts
    If you want a cleaner install (no wires hanging from the battery), there's a pin in the fuse panel under the hood that has constant power and is powered directly from the battery. If you pop the cover on the under hood fuse panel, it's the bolt located at the front, passenger side of the fuse panel. That is the bolt that powers the fuse block so it is power taken directly from the batter. This lets you run everything concealed and not have wires hanging off the battery terminal (one of my pet peaves, I'm a little OCD when it comes to wiring :eek:)
  9. Jan 26, 2012 at 5:56 AM
    Pugga
    Massachusetts
    Not if the switch is powered by something that's only hot when then ignition is on.
  10. Jan 26, 2012 at 7:51 AM
    TacoFMS
    Justin
    Louisa County, VA
    i thought he was saying that he was going to wire the switch directly to the battery???? im a lil confused now cuz it seems ambiguous on how im reading it.
  11. Jan 26, 2012 at 9:27 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    LOL..no...I'm going to wire the wire coming from the switch to the fuse block inside the cab. :eek:
  12. Jan 26, 2012 at 9:30 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Great info...I'll look at this. Going for the install after lunch and baby girl goes down for her nap.
  13. Feb 7, 2012 at 7:16 PM
    bootboiler
    bootboiler Well-Known Member
    Scott
    Santa Cruz
    Camberg UCA's, locking tailgate, hid driving lights, B 5100's, OME HD Leafs, bud built plates, Relentless rear bumper, sliders with kick, breathers on pumpkins, satochi grill, bed lights, JVC 730BT Head Unit, Finch Four Wheel Camper FWC, 1Up bike rack, 265/75 16 tires
