Piaa 5454 Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bc_tacoma10, Apr 17, 2011.
  1. Apr 17, 2011 at 1:19 PM
    bc_tacoma10
    bc_tacoma10 [OP] Well-Known Member
    Rick
    Kelowna, BC
    10 Access Cab SR5 Black
    Installed the Piaa 5454 kit this weekend. Lights are nice and bright, more so than the headlights. They look great and fit pretty good. Good job Piaa :cheers:
  2. Apr 17, 2011 at 1:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's a lot cleaner than the last install I saw of that kit. The last person who posted up with the 5454 kit had a horrible fit, you could see the set screws and they stuck out of the fog light holes a lot more. That install looks much much better! Did you do it yourself or have a shop do it?
  3. Apr 17, 2011 at 1:52 PM
    bc_tacoma10
    Rick
    Kelowna, BC
    Ya I saw the other thread and noticed the screws showing. I was worried about that but we didn't run into that problem at all. My buddy owns a truck accessory place so we did it ourselves. Weird how that other guy had troubles. The lights are awesome, I would recommend!
  4. Jul 25, 2011 at 1:04 PM
    Pugga
    Massachusetts
    What does the 'mounting hardware' consist of. I'm thinking about picking up a set of 540's but I can't find just the mounting hardware without the lamps.
  5. May 31, 2012 at 6:21 AM
    Pugga
    Massachusetts
    With the 5454 kit, you can't put the grill on the lights. If you want the grille over the lights, you need to use PIAA 510's. Anything you put over the lights will affect light output to a degree. Personally, I'd say the light output lost is negligible.
