PIAA H3 intense white bulbs-a short review
Discussion in 'Lighting' started by Motorshooter, Nov 29, 2010.
  1. Nov 29, 2010 at 10:07 AM
    Motorshooter
    Motorshooter [OP] Motorshooter
    VA-Northern VA
    16 double cab, short bed, 4X4 SR5, Towing pkg. Inferno Orange -What a great color!
    Weather Tech stone guards, Undercover SE bed cover, Rhino running boards, modded N-Fab light bar with two Hella 7" Driving lights, 2 Ridged cube fogs, fresh coat of wax. I really miss my Indigo Ink Pearl 07' DC -RIP-she saved my life. Thank you blue beast!
    Yep, I replaced my stock head light bulbs with PIAA H4 intense white replacement bulbs….thanks for a point to by a few TW posters.
    The difference is staggering. The old bulbs (OEM) were 3 years old. The headlight beam color was yellow-whitish, and did not project well down the road.
    The PIAA bulbs project a cleaner, stronger beam without a yellow cast.
    I can really see the difference in bulb clarity when I have the headlights and the stock Taco fog lights on together. PIAA headlight bulbs-nice clean light, the fog lights look very yellow and don’t high light the sides of the road well.
    Now it’s time to research a good quality H10 fog light bulb, PIAA doesn’t produce one.
  2. Nov 29, 2010 at 10:12 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'm curious to hear how long they last. I've heard some comments on here about them having a short life. I ended up going with Philips X-Treme and Nokya yellow H10's for fogs (I don't have them yet, just ordered on Amazon, I'll let you know how they do).
  3. Nov 29, 2010 at 10:17 AM
    Motorshooter
    VA-Northern VA
    I'll keep you posted. To me my old OEM bulbs started to fade around the 3 year mark. I'll be happy if I can get that out of my new bulbs.
    Most of the folks I talked to siad they got about 3-4 years from their PIAA bulbs
  4. Nov 29, 2010 at 10:20 AM
    Pugga
    Massachusetts
    F-150 Mod
    Nice, hopefully they hold up, I've heard great things about the performance of their bulbs. I experienced the same thing with my headlights, I'm right at the 3 year mark and started noticing them dulling out. Do you want white fogs also, or are you looking at yellows? I've heard decent things about the nokya bulbs if you want yellow. Otherwise, i'm not sure if the Philips X-treme or Silverstars are available for the fogs but they're good options if you want white.
  5. Nov 29, 2010 at 10:35 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    I too had the intense whites in my 06 Prerunner. I have switched to Hella bulbs as the PIAA's were TOO white to do any good in bad weather. Fog and rain = road side reflectors only and no visible light on the road surface. I might switch back to them in the spring as the dry road performance is hard to beat on low beam. High beam is too high to do much good due to the filament being moved inside the bulb (I compared the PIAA to the Hella and the stock Sylvania bulbs) throwing the reflector to bulb angle off......
    I'll be interested to see how the Nokya H10 yellow fogs work as I'm leaning towards them in the future......
    PS I had PIAA bulbs in my BMW Motorcycle for 5+ years and never had to replace them......
  6. Nov 29, 2010 at 11:27 AM
    Motorshooter
    VA-Northern VA
    I'd like to stay white, I noticed the Nokya white bulbs. The reviews are good on those also
  7. Nov 29, 2010 at 11:31 AM
    Motorshooter
    VA-Northern VA
    I'v had good luck with my PIAA bulbs since I dropped them in. Fog and rain, they really seem to light up the road to where I can see it very well.
    In the fog they put out a good quaility shaft of light
    After my bulb upgrade I'll be shopping for a good deal on the Hella 500FF fog light kit.
    Nice beam braodcast out front and a good upclose pattern as well
  8. Jan 16, 2012 at 11:13 AM
    Motorshooter
    VA-Northern VA
    Update-just over a year and both PIAA H4 intense white replacement bulbs burned out in Dec 11.:mad: I put my old OEM bulbs back in...they still do a good job
    I won't be spending $$ on PIAA again:(
  9. Jan 16, 2012 at 11:51 AM
    Pugga
    Massachusetts
    F-150 Mod
    Crap... I just went to PIAA Xtreme White bulbs a few months ago. One of my Philips bulbs blew when I got hit and thought PIAAs would be a good replacement, apparently not :(
  10. Jan 16, 2012 at 11:57 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    F*ck, just going out to put HB3s & HB4s in the 4Runner this afternoon.
    Oh well, we'll see how long they last.
  11. Jan 16, 2012 at 12:03 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    PIA makes crap products.
    See my review of PIA 510's for reference.
    If you want good bright light get some Narva Rangepower 50 bulbs from here http://www.candlepowerinc.com/products.pib.html
    Same price, but good lights....and stay away from "filtered" bulbs with that blue tint shit on it. It blocks light - that's what tint does. It only makes you think it's brighter cause it looks whiter. Take the tint off and the same bulb will shine more lumens farther distances.
  12. Jan 16, 2012 at 12:04 PM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Its hit or miss with the bulbs had one burn out 3 months after I put them in brand new. The other bullb is still going strong 10 months later. I just picked up 2 extra bulbs the other month So when the burn out I am ready to swap them. Not a big deal just buy the extra bulbs keep em in the truck. Found them on Amazon or 4wheel parts for 30 bucks.
  13. Jan 16, 2012 at 12:08 PM
    Pugga
    Massachusetts
    F-150 Mod
    Except for the fact that swapping the bulbs is a royal PITA unless you have some tiny hands. I'd love to meet the bozo responsible for putting the battery right behind one headlight and the windshield washer fluid reservior right behind the other one :mad:
  14. Jan 16, 2012 at 12:12 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Hey sorry I was referring to the bulbs for the fog lights. I thought i mentioned that sorry :( I put in the ATP 510 for the fogs
  15. Jan 16, 2012 at 12:15 PM
    Pugga
    Massachusetts
    F-150 Mod
    Oh... I've had great luck with the PIAA bulbs in their lamps. I'm going on 3 years for my 520 driving lights and no issues.
  16. Jan 16, 2012 at 12:28 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I remember Pugga your the one that talked into it :) I am thinking about getting the bulbs for the headlamps now. Till I have the money for HID, Trying to save up for a lift and wheels now.
  17. Jan 16, 2012 at 1:13 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm at 3 years, and counting, on my PIAA Intense White headlights. No problems, so far...
  18. Jan 16, 2012 at 2:25 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Just finished putting these in my 4Runner. Got my 13yr old son to help get the ones by the reservoir and battery out for me!
  19. Jan 16, 2012 at 4:54 PM
    Pugga
    Massachusetts
    F-150 Mod
    :eek:
    I love the light output from them, but I'll be pissed if they don't even last a year!
    If you go HID, make sure you get projectors! I really like these headlights as an alternative to projectors because I didn't want to go through the project of retrofitting.
  20. Jan 16, 2012 at 9:39 PM
    XXXX
    sKiP
    05 Prius
    Your right. They are not DOT approved and are from Germany and meet EU standards which are superior to US standards IMO.
    With that said as long as you don't get a higher wattage bulb then OE you won't be blinding anyone.
