Piaa Headlight Bulbs
Discussion in 'Lighting' started by Logan22, May 24, 2012.
  1. May 24, 2012 at 10:07 AM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    I am wanting some headlight bulbs that illuminate white with no yellowish tent. Also I want to be able to just put them into stock housings, wires, etc. I was thinking about getting the Piaa Extreme White. Would these work fine for what I want. Also does anyone have any pics of these on their truck, I would really appreciate it if someone could post them. Do you have any other suggestions?
  2. May 24, 2012 at 10:19 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've had the Sylvania Silverstars and they were exceptionally more white then the stock bulbs and I liked them cause the light output was better too. I'm sure the PIAA's are good as well but you will be paying a bit more for those.
  3. May 24, 2012 at 11:05 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Narva Range Power 50 http://store.candlepower.com/naraulhiou551.html
    Those PIAA/Sylvania/whoever coated bulbs everyone loves suck IMO.
    All the bulbs have the same wattage so:
    Coating = less light
    No coating = more light
    Stolen from another forum:
    I'd highly recommend the Osram Silverstars. These are like the Euro version of the Sylvania Silverstars and have won most magazine shootouts for several years AND they last longer than the Syl. Silverstars WITH better light output.
    Go to Daniel Stern Lighting Consultancy and Supply to buy them in the US. Outstanding bulbs to try in the FJ. There are 4 that are almost identical; Philips VisionPlus, Osram SilverStar, Narva RangePower+50, Tungsram Megalicht. Better than my PIAA's were.
    Go here to see a review of the Osram's:
    Bulb test - H7 + 50 | Product Tests | Car Reviews | Auto Express
    If you want something really sweet, buy the Osram Ralleyes. I bought a set of them but I am upgrading my wiring harness to really take advantage of them as they are 70/65W bulbs and the Toy's wiring needs a little help as I am getting some voltage drop as it is now and this will just make it worse.
  4. May 24, 2012 at 11:07 AM
    XXXX
    sKiP
    05 Prius
  5. May 24, 2012 at 11:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got the PIAA Xtreme white bulbs and like them. They have a good beam pattern and are white. Here's a pic of the light output color.
    Here you can see they have a slightly blue hue in the headlight housing when the lights are off.
  6. May 24, 2012 at 11:19 AM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Thanks, the picture helped alot. You don't have to change any wiring or anything do you for these bulbs?
  7. May 24, 2012 at 11:22 AM
    XXXX
    sKiP
    05 Prius
    just buy Narva for the same price if not cheaper :confused:
    :D
    As long as you don't get grease on them a strait razor will peel the coating off of them. It would be labor and time intensive.
  8. May 24, 2012 at 11:29 AM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Does anyone know which piaa extreme white model I would need?
  9. May 24, 2012 at 11:32 AM
    Pugga
    Massachusetts
    Here's what you'd need:
    9003/HB2/H4
    No wiring required, unplug the old bulb, undo the retainer clip, install new bulb, plug in and done. Just make sure you don't touch the glass part of the bulb. It might help to wear nitrile gloves.
  10. May 24, 2012 at 11:39 AM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Thanks alot
  11. May 24, 2012 at 2:15 PM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Do you think the extreme white plus would be even better? They cost a little more.
