Piaa light kit #5454 for tacoma installed
Discussion in 'Lighting' started by squiggy, Mar 4, 2010.
  1. Mar 4, 2010 at 3:25 PM
    squiggy
    squiggy [OP] Well-Known Member
    Vermont
    2019 Tacoma 4 door long bed TRD OFF ROAD
    none yet
    Hear are a couple of pictures of my Tacoma with the new Piaa light kit made for the Tacoma. They are bigger than the stock lights so there not recessed into the bumper as far. Little disappointed.... thought they would be closer to the size of the stock lights. How do you think they look?
  2. Mar 4, 2010 at 3:35 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Take a close up picture. How easy were they to install and where you get them from?
  3. Mar 4, 2010 at 4:30 PM
    squiggy
    Vermont
    none yet
    I called Piaa to see if the kit was available and they told me it was. I ordered them from a local accessories store called ADD-ON and had them install them. I didn't have good or warm place to install them. It took them about 1.5 hours to do them.
  4. Mar 4, 2010 at 4:35 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    whats the difference?
  5. Mar 4, 2010 at 6:57 PM
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I installed mine on Wednesday, I was disappointed in the fit. It was a pain to line everything up for me, and they hang out pretty far. To get around having driving lights in there, i bought a set of the Piaa 540 plasma ion fogs, and swapped them in. I'll use the driving lights on my avid bar once i get it installed.
  6. Mar 5, 2010 at 11:03 AM
    squiggy
    Vermont
    none yet
    Did you just buy the lights or do you have to buy everything...and do they plug into the orignal harness ?
  7. Mar 5, 2010 at 2:51 PM
    swendling12
    Sean
    Nebraska
    I bought the Piaa 5454 Kit, which comes with a wiring harness, Piaa 540 driving lights, and a bracket to make them work in the factory slots (kind-of). I also bought the Piaa 540 Plasma Ion Fogs w/ a wiring harness also. I then swapped the fogs and driving lights around so that i could have fogs in the factory spots, and so that i could have driving lights on my avid light bar.
    The Piaa's are not designed to use the factory harness, in the instructions, they instruct you to just move the factory wires out of the way and to use the harness that they send. Their harness is pretty easy to wire up, the hardest part was getting the wires through the firewall into the cab. The lights do not attach to the back of the fog socket like the factory ones do, rather they are screwed through the sides of the cups.
    -Sean
  8. Mar 12, 2010 at 9:05 AM
    squiggy
    Vermont
    none yet
    Does the bracket from the 540 foglights fit on to the driving lights so that you will be able to mount them on the light bar?
  9. Mar 12, 2010 at 2:15 PM
    swendling12
    Sean
    Nebraska
    I was able to simply disassemble the 540 driving light assembly that came with the kit, and the plasma fogs that i bought and swap the pieces around to work for me. took maybe 5 mins total... 2 screws on each light. Was easy and works great.
  10. Mar 13, 2010 at 2:15 PM
    swendling12
    Sean
    Nebraska
  11. Mar 13, 2010 at 2:23 PM
    squiggy
    Vermont
    none yet
    Looks great...I will have to pick up some 540 foglights and get to work on them.
  12. Mar 15, 2010 at 2:59 PM
    mcampos0
    mcampos0 Today I Will!!!!
    Mark
    EL Paso
    09 DC Pre
    Mud Flaps Off, Window Tint, Keyless Remote w/ Kill switch n Alarm, Straps for shovel in back, Avh-3100DVD, 3in toytec lift, 285/75/16 Nitto tera Grapplers on stock 16 wheels, Polk Audio MM speakers all around
    Hows the light output on those piaa's fog lights. And did the fog lights come with the piaa light cover??
  13. Mar 15, 2010 at 3:48 PM
    swendling12
    Sean
    Nebraska
    The Plasma Fogs are a blue/yellow light. They are not exceptionally bright since it isn't a white light, but do a decent job of lighting up the area directly in front of the truck. The PIAA 5454 kit does not come with covers since the covers will not fit on the lights once the lights are in the socket, the lights themselves barely fit. The PIAA 540 plasma ion fogs that I bought came with the plastic covers. I just moved the covers over to the driving lights on my Avid Light Bar.
    -Sean
  14. Apr 7, 2011 at 1:25 PM
    hey505
    hey505 Active Member
    So I am still unclear..do the PIAA #5454 vehicle specific lights fit and wire to the stock harness and switch ? I was told by PIAA that they did but saw some posts saying they didnt..:confused:
  15. Apr 10, 2011 at 6:45 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I just ordered the 510 ATP to put in the fog holes. I hope i can just get them to fit as well as your did
  16. Apr 10, 2011 at 8:26 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I do think they look like they are not made for the Tacoma. It seems like they are sticking out too far, not factory installed.
  17. Apr 10, 2011 at 10:40 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    schley, ya I though the same thing I looked at some of the pictures from people who installed the 510's in there factory holes and they look really clean. And from what said the ATP light was perfect combination of fog driving light goes really well with high beams on back roads. So I ordered those and hope to install this week
