Piaa lights and other switch
Discussion in 'Lighting' started by longbow, Apr 13, 2009.
  1. Apr 13, 2009 at 7:40 AM
    longbow
    longbow [OP] I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    :confused: Trying to get my new Piaa's to run off of one of these, since I am to chicken to tap into and use the stock fog switch.
    I have the ground and power wires running to my Blue Sea fuse block, but when I run the other wires to the switch all I get is the led light on the switch to light up, I get nothing else. If I use the Piaa switch it works.
    Any idea of whats going on??
  2. Apr 13, 2009 at 7:41 AM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Are the lights properly grounded? Try that. Simple things first.
  3. Apr 13, 2009 at 7:42 AM
    01GREENTACO
    Germantown, TN
    01 4WD
    Those switches are bad ass too... where did you get them? I think I want to pick up a few!
  4. Apr 13, 2009 at 7:46 AM
    longbow
    Bill
    Indiana
    Switches are from the dealer, yea everything is grounded, via the new fuse block.
    Like I stated, with the Piaa switch they work, but with the others they don't
  5. Apr 13, 2009 at 8:12 AM
    01GREENTACO
    Germantown, TN
    01 4WD
    Maybe you just have to use the provided PIAA switch.
  6. Apr 13, 2009 at 8:24 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I have my Piaa's running to those exact switches, Just gotta remember how the wiring went, you should have three wires. Black, Red, and White. With the switches in the panel the direction you have them white on top post red/middle post black on bottom post.
  7. Apr 13, 2009 at 8:26 AM
    Dark Knight
    Jeff
    NC/SC
    oh to add those wires are from the original piaa switch harness. I just hacked it off at the base of the on/off switch and then stripped back the sheathing to expose those 3 wires
    Edit: makes better sense now
  8. May 30, 2012 at 12:20 PM
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    Thread bump!
    Did you ever get the switch to work, OP?
    I am in the exact same situation. I tried to use on of those contura rockers and it didnt work. Then when I re-wired the Piaa switch it worked..
  9. May 30, 2012 at 12:33 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can wire PIAA lights to another switch, I've got a pair running off a factory fog switch and another pair running off an Autozone switch. As long as you have your wires correct, there's no issue. Trace your wires and make sure the wires you run to the switch are in the correct order (power in, power out and ground).
