piaa off road hook up
Discussion in 'Lighting' started by bajamoon, Mar 9, 2009.
  1. Mar 9, 2009 at 1:43 PM
    bajamoon
    bajamoon [OP] Well-Known Member
    STEVE
    Whittier
    Just finished hooling up my piaa 520's and ran the switch power straight to the battery, is there going to be any problems that might accur, or should i just run the two switch wires to the fuse box. thanks in advance.
  2. Mar 9, 2009 at 1:56 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    You shouldnt have any problems. did you wire it according to the PIAA diagram that came with the lights?
  3. Mar 9, 2009 at 2:01 PM
    bajamoon
    STEVE
    Whittier
    ya, it's correct but wired the switch light to the battery instead of fuse box so i can run them if the truck is off, not that i am going to but you never know. Thanks Knight.
  4. Mar 9, 2009 at 2:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on the switch light going to the battery, you may wanna put an inline fuse link in there, right before the battery..........................the fuse will pop before the lights do, and use a 15 amp fuse.
  5. Mar 9, 2009 at 2:06 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    "switch Light" as in the little white wire with the red dash marks (PIAA wiring harness only)? If thats the one you hooked to the battery along with the regular larger gauge positive wire you should still be ok, but you should piggy back it off your parking lights.
  6. Mar 9, 2009 at 2:09 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    To add if they are the 520 Ion crystal fogs they should be piggy-backed off the parking lights. If they are the 520 Driving lights the switch wire (white-red) should be piggy-backed off the high-beams.
  7. Mar 9, 2009 at 5:57 PM
    bajamoon
    STEVE
    Whittier
    ya it is the white wire with the red marks on it, i have two sets of the 520 smr, one is extreme white and the other is yellow, i will go to radio shack in a couple of days and buy an inline fuse just to be safe. if i was going to put it in the fuse box which fuse whould i put it in to, i want to be able to turn those lights on without turning the running lights on or headlights.
  8. Mar 9, 2009 at 6:16 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Not sure about running it to the fuse box but If you want them on with no other light definitely put the fuse in there like tacomaman06 said.
  9. Mar 9, 2009 at 6:19 PM
    bajamoon
    STEVE
    Whittier
    thanks Knight for the help and everyone else that chimmed in, you guys are the best.
  10. Mar 11, 2009 at 1:43 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Personally I wouldnt piggy back off the highs, I like to be able to use my lights whenever i want. not just when my highs are on
  11. Mar 11, 2009 at 2:00 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    my 510 fogs a switched to the parking lights so the work when ever i want with the parking lights on, the 520 SMR's are switched to the highs because there is no situation I would ever use them not as high beam lights, there just too bright. So in the end the High beam output with the 520 SMR's is like looking at the sun from 20 feet away.:D
  12. Mar 11, 2009 at 8:38 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Hahah nice! I just like the option to turn them on as I please. When it snows around here Ill point my middle 2 lights down so they are shining about 15-20 feet in front of me, that plus my hid's lights up the snowy roads pretty well.
