Piaa SMR or ATP?
Discussion in 'Lighting' started by quattrokiwi, Nov 20, 2010.
  1. Nov 20, 2010 at 7:18 AM
    quattrokiwi
    quattrokiwi [OP] Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    So maybe somebody with these lights could enlighten me. I'm going to be putting lights on my shrockworks style plate bumper.
    My question is in the 4" cut outs in the bumper should I go with 510 smr or atp? this would be in combination with some 520 atp on top in the middle.
    Something like this
    Thanks for any thoughts.
  2. Nov 20, 2010 at 7:46 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    How about some Hella 90mm headlight modules instead? Way cheaper, and probably better output. Rallylights.com sells the H9 high beam patterns for I think about $50/ea. The newer H1 housings are a bit better, but may be a lot harder to find in the US.
    They also make low beams, bi-halogen, and an array of Xenon.
    90mm is about 3.5".
    It may not be the solution if you are looking specifically for a fog pattern.
