Pic Request 2001-2004 Tacoma Purge Valve Connector
Discussion in '1st Gen. Tacomas (1995-2004)' started by Spike Strip, Aug 17, 2023.
  1. Aug 17, 2023 at 11:32 AM
    Spike Strip
    Spike Strip [OP] Well-Known Member
    2023 TRD OR DCSB
    I'm going to use this Purge Valve (Vacuum Switching Valve 90910-12245) for another application. It's found on 2001-2004 and 2000-2002 4Runner, 4 and 6 cyl.
    Trying to source the proper connector and it would really really help if I could get a picture of one face-on.
    Attached is a youtube screenshot of the valve an its location in a Tacoma, next to fuse box, with attached connector
    Couldn't find any in a junkyard.
    Thanks for any help!
  2. Aug 17, 2023 at 11:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's the EVAP purge solenoid or "EVAP VSV". I probably have the connector somewhere at home in a spare harness. But you should be able to dig it up with one of those names.
    Spike Strip[OP] likes this.
  3. Aug 17, 2023 at 11:46 AM
    Speedytech7
    This is the picture you want I'd assume though, it's a side keyed connector unlike the more common VSV connectors with bottom keys (the orange and blue ones)
  4. Aug 17, 2023 at 11:50 AM
    Speedytech7
  5. Aug 17, 2023 at 12:05 PM
    Spike Strip
    2023 TRD OR DCSB
    I ordered a 90980-11162 pigtail (aftermarket). Toyota just calls the valve, a 'Vacuum Valve' or Valve, Vacuum on the box. Clearly some differences in nomenclature.
    I have a couple FJ60's, and on the charcoal cannister, there's a 'Outer Vent Control Valve' which is the same but with an early style connector. Long NLA and used units are junk.
    Just trying to adapt this later one to the FJ60 Evap system, since I'm stuck in Kalif Smog Hello.
    Thanks for the help!
    Speedytech7 likes this.
  6. Aug 17, 2023 at 12:07 PM
    Speedytech7
    Oh I gotcha, I'm all to familiar with flubbing NLA parts with more common newer ones. Just had to do that with a 100 series center diff lock actuator on my 80 series since that actuator is NLA now. Good luck passing smog, I hope that valve does what you need it to. The earlier valve from the 96-2000 tacomas is more common and cheaper if you need to source another one BTW.
  7. Aug 17, 2023 at 12:37 PM
    Thad
    Thad Well-Known Member
    Thad
    Pittsburgh
    2004 Tacoma
    I have a good used valve if interested.
  8. Aug 17, 2023 at 12:40 PM
    Spike Strip
    2023 TRD OR DCSB
    I think the earlier one is the 90980-12130 Valve and it's a bit different (if I have the correct part #). The later one (12245) has much larger ports, same size as the FJ60 Evap hoses and will bolt right up; don't know if the size differnece means anything, but I'd like to try and keep as close to OE as possible. Just want to try and get the waterproof connector right so it looks factory. :)
  9. Aug 17, 2023 at 12:41 PM
    Spike Strip
    2023 TRD OR DCSB
    I have the valve new, it's still available from Toyota, but thank you.
  10. Aug 17, 2023 at 12:42 PM
    Speedytech7
    I was actually thinking of 25860-75160, which is the same hose size as the other you posted.
    Uses the normal VSV connector with the bottom keying though
  11. Aug 17, 2023 at 2:05 PM
    Spike Strip
    2023 TRD OR DCSB
    I haven't seen that one before, looks like it would work. Thanks!
  12. Aug 20, 2023 at 2:29 PM
    Spike Strip
    2023 TRD OR DCSB
