pic request
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Jan 20, 2010.
  1. Jan 20, 2010 at 7:45 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Anyone care to post pics of 5100's set at 0 with eibach springs? thinking of this set up to match my rear TSB..
  2. Jan 20, 2010 at 8:13 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    I have the Eibach's on my stock TRD billys. (Check my gallery) :thumbsup:
  3. Jan 20, 2010 at 8:38 AM
    BSP4x4
    BSP4x4 [OP] Guest
    how do you like them? are you talking about the blue/yellow billy's?
    how much lift do you get in the front?
    What color are your springs? and what size tires?
    I thought i read a thread on here saying that this setup is not suggested because the stock billy's can't handle the springs or something?
    how is the perfromance of your setup?
    THANKS!
    anyone else wanna chime in?
  4. Jan 20, 2010 at 8:40 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    search around the last toytec group buy thread. That was one of the configurations offered (bilsteins and eibachs).
    I run the eibach 1.6 springs and 5100s, but I set my snapring to the second indentation (0.85"). Combined with the lift springs, it gives about 2.4 inches of lift and a very nice ride.
  5. Jan 20, 2010 at 8:47 AM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone else running the eibach with the stock blue/yellow billy's? care to share how it rides?
  6. Jan 20, 2010 at 9:03 AM
    Burns
    NJ
    17 DCSB Off-Road
    None!
    Yes I have the yellow and blue billys that you get when the suspension TSB is done. I have very happy with the setup.
    I got about an inch of lift. (pre-runners have gotten 1.6 inches of lift)
    I am running 265/75/16's.
  7. Jan 20, 2010 at 9:14 AM
    BSP4x4
    BSP4x4 [OP] Guest
    do you know why the pre runners get a little more lift?
    anyone else running the STOCK blue / yellow billy's with eibachs?
  8. Jan 20, 2010 at 9:23 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    from what i've seen the prerunners aren't as low in the front as 4x4's in stock form...i guess since they have less weight on the front...they seem to only be about 1" lower in the front where as the 4x4's are about 2.5" lower in the front than the rear...the general settings i've seen on here when running 5100s is if you have a prerunner go with 0" and if 4x4 go with .85" setting when running the eibach 1.6" springs...this is after having the tsb done...if no tsb the settings would be different...also reg cabs don't have a tsb for them for those that have a reg cab...if someone has a reg cab it will look like the others after they have the tsb done...about 1" rake on a prerunner and 2.5" rake on a 4x4....i guess there are always variations but just measure and see where you stand
  9. Jan 20, 2010 at 9:35 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I have Eibachs with 5100's set at 0". I also have the Toytec top plate spacer. The spacer is 0.5" thick and is supposed to provide about 0.75" lift. I chose the spacer over moving up the 5100's a notch so that it wouldn't preload the coil. I wanted it to stay as flexy as possible for wheeling. I got just a hair over 2" lift out of this set up. It is basically dead level with my TSB rear.
    I'm intending to add aftermarket bumpers and skid plates soon. This will pull the front back down a little and I'll probably move the 5100's up to 0.85". I'm guessing this will put me back up in the 2.5"-2.75" area. Depending on looks, I may or may not do an AAL too.
    The set up I have now rides beautifully and gave no issues on alignment with stock UCA's.
  10. Jan 20, 2010 at 9:41 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Maybe, because they have a lighter front end. We pm'd, and yes I'm running stock billies w/ eibach and tsb. There is a little rake, but it works out when I have my quad trailer hooked up. Unfortunately a quad in the bed and trailer hooked up is another story.
    My plan is to wait until these stock billies go to shit before I pick up 5100's. I will probably get toytec top plates in the near future.
  11. Jan 20, 2010 at 9:41 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Pre runners have a much lighter front end. They do not have the weight of the transfer case, front differential, and CV axles pulling down on the suspension.
  12. Jan 20, 2010 at 10:02 AM
    Burns
    NJ
    17 DCSB Off-Road
    None!
    I plan on doing the same.
  13. Jan 20, 2010 at 10:09 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    It may or may not make a difference or be relevant but something to consider anyway... I sold my blue and yellow billy's with the oem coils (had about 4500 miles on them) for enough money to pay for most of the Eibachs. They sold fast too.
  14. Jan 20, 2010 at 10:12 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Hmm...maybe I can sell them enough to help pay for my 5100's. It is something to consider. Thanks.
  15. Jan 20, 2010 at 10:22 AM
    BSP4x4
    BSP4x4 [OP] Guest
    thanks! anyone else running eibachs with stock blue/yellow billy's?
