pick-a-paint for my wheels
Discussion in 'Wheels & Tires' started by FEARFACT, Sep 17, 2012.
  1. Sep 17, 2012 at 4:23 PM
    FEARFACT
    FEARFACT [OP] Well-Known Member
    03 double cab 4x4
    coilovers,33s etc
    basically the budget is low and i need to mess around with something. the finish on these wheels is messed up and has a lot of oddball discolorations that dont come off with scotbright pads and elbowgrease, plus i just want a little change. no powder coat since i do wheel it and they will get FUBARd so i need to be able to repray if required.
    ill replace the fiftyfukbillion screws that are needlessly installed on the bead since many are missing and all are corroded to hell as well
    im thinking black will look the best, or possibly a gunmetal but looking for opinions/pics/ms paint catastrophes etc. thanks for the helps guys/gals
  2. Sep 17, 2012 at 4:26 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    Red with a Sliver LIP
  3. Sep 18, 2012 at 6:09 AM
    FEARFACT
    03 double cab 4x4
    coilovers,33s etc
    All for a small splash of color but that may be a bit much... You did get the wheels turning though.... Those holes machined into the dish have about a 1/4 bevel, maybe that red to play off the little red detail I TRD, then black everything else..not quite what I see everyday but not gawky/bro'd out... And if it sucks it'll be easy to lack out completely.
  4. Sep 19, 2012 at 1:48 PM
    FEARFACT
    03 double cab 4x4
    coilovers,33s etc
    used my excessive comupter skills to render 2 ideas... i like the back wheel, pretty sure ill pick up the paint and pull a wheel of Saturday and see if i like it when it looks less like helen keller attacked with crayolas...im thinking the minimal red just on the center caps where it says the eagle alloy stuck will be enough and black paint to the useless screws around the bead area... the red ring idea wont really work because it doesn't have a fake beadlock ring, just recepticles cast into the wheel.... kind of a TRD rip off, and im good with it..
  5. Sep 20, 2012 at 12:15 PM
    FEARFACT
    03 double cab 4x4
    coilovers,33s etc
    got out of work early so i stopped at autozone and picked up 2 can of wheel paint, a sanding block and a red touchup paint pen..... had a $20 dollor credit so this entire project cost me about 7 dollars since i had black paint and just painted the hardware black.... 2 wheels done, do the other 2 on saturday..
    whatchathink
  6. Sep 20, 2012 at 12:35 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    well hot dayum!
    for $7 sir. You gotcha yourself a deal.
    Can't beat that with a rubber hammer!
