pick up vib after installing billies!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chays, Apr 23, 2012.
  1. Apr 23, 2012 at 3:48 PM
    chays
    chays [OP] Well-Known Member
    mississippi
    2005 tacoma dc 4x4,2012 tacoma trd ofr 4x4dc
    moto metals and more!!
    set them at 1.75 to level truck.
    now i can hear a vibrations between 55
    and 65,but really dont feel it in truck.
    you can let off gas and it goes away.
    any suggeestions?
    2006 acc cab 4x4 long bed.
    thanx,
    chays
    p.s. i also installed 1" toyotech rear blocks.
  2. Apr 23, 2012 at 3:51 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
  3. Apr 23, 2012 at 4:19 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Is the vibe front or rear??
    Place vehicle in 4hi and see if the vibe goes away. If it does then you have a front diff vibe which can be solved with a new bushing from ECGS.
    If it is still there it is more than likely the rear and you will need to shim axle as needed by using a driveline angle finder to find correct degree shim needed. Can try the carrier bearing as stated above as well.
