pick your poison, jacked up or low lift with wide stance?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mothermucker, Jun 16, 2014.
  1. Jun 16, 2014 at 4:04 PM
    mothermucker
    mothermucker [OP] Active Member
    Reilly
    BC Canada
    03 Tacoma TRD off-road
    i have a 4 inch lift and I'm not happy yet:roll eyes: I'm wondering if i should lift it higher or or go for a bigger wider tire. Im wondering how hard spacers are on the truck and if i could still get the look i want by just going with a wider tire.
  2. Jun 16, 2014 at 4:04 PM
    Large
    Large Red
    Got any pics? Do you wheel it at all?
  3. Jun 16, 2014 at 4:09 PM
    mothermucker
    Reilly
    BC Canada
    sorry past owners company decals are still on it so i can't post pics yet, they're getting the heat gun tonight :yay:
    And yes thats pretty much all i do with it so can't be super wide don't want it ridiculously tall either though :confused:
  4. Jun 16, 2014 at 5:00 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    Keep it low and wide...
    Is it a drop bracket kit, or cracked up coils? If you have the DB, I'm very sorry about your luck :) haha
    Droop>up travel
  5. Jun 16, 2014 at 5:41 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Hey! Deppending on the size of tires you have now you could make it a little taller with larger tires. with that said, bigger tires also make it look wider. Ive ran spacers and i didnt have a problem. Its 50/50 on opion of spacers. Ive seen a tire come off on free way tho due to spacers. lol If you get spacers just buy nice ones and not cheap ones. Hope this helps!
    Tim
  6. Jun 16, 2014 at 5:50 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    imo, if you go higher than 4", you will run into COG issues when wheeling. I vote to get some wheel spacers to get a wider stance.
  7. Jun 16, 2014 at 5:53 PM
    mothermucker
    Reilly
    BC Canada
    Thanks! I'm thinking 34" but not sure what my max width would be??what determines how wide you can go without spacers?
  8. Jun 16, 2014 at 5:56 PM
    mothermucker
    Reilly
    BC Canada
    Thanks i think you're right, is there a certain spacer you would recommend?
  9. Jun 16, 2014 at 5:58 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Bora
  10. Jun 16, 2014 at 5:59 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    watch the heat gun if you're using it to remove stickers over paint...it'll take paint off too...
  11. Jun 16, 2014 at 7:15 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    No. Spidertrax. Wheel and hub centric. Best spacers on the market.
  12. Jun 16, 2014 at 7:56 PM
    TimPall13
    Tim
    Sandy Oregon
    I agree! Spiertrax has a great review and always heard good things about them. and for tire size i run 33x12.5 and it a wide tire. i have a 3" lift so 33s wouldnt look bad under yours. if you want 34s though id just look up the tire you are wanting and see what the width is for it. :)
  13. Jun 16, 2014 at 8:07 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Bora spacers are hub centric too.
  14. Jun 16, 2014 at 8:12 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Low n wide FTW :D
  15. Jun 16, 2014 at 9:24 PM
    mothermucker
    Reilly
    BC Canada
    Thanks for the feed back :) i really like toyo's because I've always ran them and never had a problem, i found a open country all terrain tire with a overall diameter of 34.5 and a width of 12.5, i just have to decide what size spacer i need with minimum amount of strain on the truck.:D
  16. Jun 16, 2014 at 9:33 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This
    1.25"
  17. Jun 16, 2014 at 9:35 PM
    TimPall13
    Tim
    Sandy Oregon
    I ran 1" spacers on my truck for a while until i got new wheels with a better back space. If you run spacers you might need to trim the plastic piece of the bumper and do the pinch weld mod if not already done. :D
