Picking a Floor Jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crackils, Dec 11, 2019.
  1. Dec 14, 2019 at 10:16 AM
    #41
    jungleman
    jungleman There can be only one
    North California
    2005 Access Cab Indigo Blue
    Havent seen this one mentioned yet.
    Old orange from hf finally died...when I loaned it out.
    I didnt go hf this time because that thing only had one speed on release...full on down!
    Sounds like the hf ones have gotten better.
    No problem lifting both fronts when I did my shocks recently.
    Love the swivel handle.
    Not a bad jack for the price and 10% off.
    I have no use for a low profile at this time.
  2. Dec 14, 2019 at 10:27 AM
    #42
    Blucuss
    Blucuss Well-Known Member
    Texas
    2018 Super White Tacoma TRD OR
    • RAVELCO ANTI THEFT DEVICE with Three Plugs • 285/75/16 BFG KO2s on Stock TRD PRO Wheels • King Front Coilovers, 700lb Front Springs, Extended Travel, Remote Res with Comp Adjusters • King Rear Shocks with Remote Res and Comp Adjusters plus DOBINSONS TACOMA HEAVY DUTY LEAF SPRINGS • Total Chaos UCAs & LCAs • 5.29’s & ARB Air Locker • ARB Twin Air Compressor on SLEE Mount • Switch Pro 9100 • North Star NSB-AMG27F Battery • OGE Machined Aluminum Battery Tiedown • Upgrade Sound System - KENWOOD DMX706S / XR9015 KENWOOD Reference Fit 5 Channel Power Amplifier/ Custom Box 10" Single Sub Ported / KFCXW1000F KENWOOD 10" Shallow Subwoofer, 1000W Max / RSE165 FOCAL 6.5” 2-Way Component Kit Door Speakers • Custom Front & Rear Viewing Cameras • Sound Dampening Mat 4 Doors, Floor, and Rear • Redline Toyota Tacoma Hood QuickLIFT ELITE - Carbon Fiber • LRA 34 Gal Fuel Tank • BAMF High Clearance Rear Bumper with Rub Rails & Dual Swing out with Tire Carrier plus dual Squadron Pro S1 Baja Designs lights • C4 Fabrication Overland Series Front Bumper with Full Center & Headlight Hoops plus Front Bumper Frame Supports / Squadron Pro, Pair, LED Driving/Combo Cubes (Amber) Fog Lights / Center LED Bar Baja Designs - S8, 30" Driving/Combo Amber,LED Light Bar • CASCADIA 4X4 FLIPSTER V3 WINCH LICENSE PLATE MOUNTING SYSTEM • WARN® ZEON 10-S Platinum Winch • GOAT - CUSTOM Go Off-road Armor Tech • Ditch Lights - Squadron Pro LED Driving/Combo Cubes • Cali Raised 25 Degree Rock Sliders • Cali Raised Bed Channel Supports • ShrockWorks High Clearance Full Belly Skid Plates All Steel Construction • High Clearance TRD Exhaust Modification • Custom Horn from American Auto Horns • upTOP Alpha XL Roof Rack with Baja Deigns 30" S8 & Squadron Pro, Pair, LED Driving/Combo Cubes Facing the Rear • Weathertech Front & Rear Floormats • G-Tec Fab Door Sill Protectors • TRD Pro Front and Rear Leather Seats • MOLLE Panel, Double Cab Subwoofer w/power window • TheTacoGarage Dashtop Multi-Mount • MESO Gas Hole • MESO Custom Fuse Cover • MESO Coin Holder • SDHQ Built Billet ABS Guards • Multimount Panel - Seat Jacker Mount • MAXTRAX MKII FJ Red Traction Boards
    I just purchased this exact one today which has a coupon code (39747897) that you can use until December 15th for additional $30.00 off of $199.00. It has great reviews. You can choose from colors black, green, or orange.
    crackils[OP] likes this.
  3. Dec 14, 2019 at 10:37 AM
    #43
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Usually the slamming down is caused by blown seals from over tightening the handle at some point.
    jungleman[QUOTED] likes this.
  4. Dec 14, 2019 at 10:58 AM
    #44
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Do you guys have any suggestions for a jack to carry with me in the truck? I just checked my truck, between having the TSB leaf springs and one size larger on tires I am not able to get the OEM piston Jack to lift the frame enough to change spare tire. I know obviously a hi-lift jack which I could mount in the bed, but I'm sure there are other things.
  5. Dec 14, 2019 at 11:04 AM
    #45
    jungleman
    North California
    Yeah it did it from the start, I should have taken it back but I told a mechanic friend and he said its a hf jack what did I expect....I shouldnt have listened to him.
    Ive just dealt with it for years.
  6. Dec 14, 2019 at 1:16 PM
    #46
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
  7. Dec 14, 2019 at 7:10 PM
    #47
    81shark
    81shark Well-Known Member
    Oooo. I need some three ton stands
  8. Dec 14, 2019 at 7:13 PM
    #48
    jungleman
    North California
    Get some!
    Gotta have em
    07 sport 4x4 likes this.
  9. Dec 14, 2019 at 7:20 PM
    #49
    crackils
    crackils [OP] Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    Thanks for posting this!
  10. Dec 14, 2019 at 8:56 PM
    #50
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    That Daytona 3ton Kicks Ass! It is the next thing on my list...
  11. Dec 15, 2019 at 4:06 AM
    #51
    cpc
    cpc Well-Known Member
    MASS/ESSEX COUNTY
    TRD PRO
    cbi front receiver, rigid lights, leitner designs, mobtown sliders, Brute Force Fab
    hi lift jack is not ideal for changing tires. Expensive option but well worth the money is Pro Eagle, light weight, plenty of height, and they sell replacement parts to rebuild it if needed.
  12. Dec 15, 2019 at 10:35 AM
    #52
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    TheDevilYouLove and crackils[OP] like this.
  13. Dec 15, 2019 at 10:40 AM
    #53
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I have AC Delco floor jacks ( not sure of actual mfg)
    I've got ....
    1.5 ton aluminum rapid pump racing jack
    3 ton heavy duty floor jack
  14. Dec 26, 2019 at 6:33 AM
    #54
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    do you know if they will they scan the coupons off your phone?
  15. Dec 26, 2019 at 7:08 AM
    #55
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Yes they will scan it off your phone.
    crackils[OP] and 07 sport 4x4 like this.
  16. Dec 26, 2019 at 1:54 PM
    #56
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    I have #3. Been working well the past 2 years. My only gripe is it's huge in my small garage.
  17. Dec 26, 2019 at 2:01 PM
    #57
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  18. Dec 26, 2019 at 2:05 PM
    #58
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    I have #3 for the last 6 months and not one complaint.
  19. Dec 26, 2019 at 6:05 PM
    #59
    furiousbob
    furiousbob Well-Known Member
    Ron
    There's a 25% off coupon on HF for NYE and NYD as well!
  20. Dec 27, 2019 at 9:06 AM
    #60
    clenkeit
    Colin
    Lakewood, CA
    And, like 99% of HF 20-25% off coupons, they cannot be used on jacks.
