Picking-up new Taco in a coupe weeks. Ask dealer to do???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jetspeed, Oct 28, 2018.
  1. Oct 28, 2018 at 12:59 PM
    jetspeed
    jetspeed [OP] Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    My 2001 4X4 manual Tacoma has finally been replaced by a new Gen 3 (very sad about this, may it rust in pieces). I would like to know exactly what I should be asking the dealer to do with my Taco BEFORE I pick it up. I ordered a 2019 4X4 Sport with a manual, OEM tonneau cover and OEM predator steps.
    The only thing I can think of having the tech's do, is changing the momentary blinker from 3 to 4 blinks and make sure all TSB's are updated. I can't assume from the factory that the TSB's are covered (I think). The other requests are simple like, please don't take through car wash, get all the keys it came with, etc., etc.
    I simply don't want to have to take it back because I discovered or wondered if they checked "this and that" once I owned it for a bit.
    Thank you, what a highly active forum!
  2. Oct 28, 2018 at 1:28 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    I would be interested to know how long it takes to get an " ordered " Sport with Manuel trans. You may be disipointed in the time it takes to get it. Good Luck
  3. Oct 28, 2018 at 1:32 PM
    LeeVanChief
    LeeVanChief Well-Known Member
    2018 OR 6Speeeed Taco
    Tell them not to bother putting on dealer plate frames.
    psmura, dspec, Cmgatz and 3 others like this.
  4. Oct 28, 2018 at 1:43 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Tell them no tire shine... that shit got flung all over my fenders.
  5. Oct 28, 2018 at 1:47 PM
    Tacoma Mike
    Southern Maine
    Recalls have to be done before sale
    TSB’S are done if there is a issue and it applies to correct the condition.
  6. Oct 28, 2018 at 1:48 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Change that momentary blinker to 7, check the rear headliner to be sure it’s all secured ( mine doesn’t fully attach in one corner, but not noticeable ), and if you decline the dealer alarm make sure they remove it.
    BlueFalconActual and whatstcp like this.
  7. Oct 28, 2018 at 1:48 PM
    jetspeed
    MD
    Funny! So far I did ask for no front plate/holes, and my "odd configuration" only took about 5 weeks from deal to door. Nov 7-10th is expected date on lot.
    Lucifer1 and Norsemanvike like this.
  8. Oct 28, 2018 at 2:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    TSB's won't be done unless you have a problem that one of them covers. TSB's are highly specific to dates of manufacture and serial numbers. Let me give you an example:
    Let's say they got a shipment of diff fluid that covered a month of production. Several months later, the supplier informed Toyota that some of that fluid MIGHT be contaminated. Toyota then checks that batch with when it was used, compares serial numbers issued and writes a TSB. Some might have gotten that fluid, some might not which is why the TSB is voluntary. This is just an example and probably not even one that could happen but you get the gist.
    Neal Gamby likes this.
  9. Oct 28, 2018 at 2:22 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Ma,e them check the propellor shaft for greasing, tighten the bolts on it, and check diff oil levels. All of mine were low and there was no lube in the prop shaft. Bolts on the prop were also barely tightened
  10. Oct 28, 2018 at 3:09 PM
    RustyTrumbone
    RustyTrumbone Well-Known Member
    Phil McCracken
    2018 Tacoma SR5 Short Bed
    It was all over my running boards and didn’t come off for a while
  11. Oct 28, 2018 at 4:00 PM
    ICU1
    ICU1 Well-Known Member
    Ask them for service department phone number
  12. Oct 28, 2018 at 4:39 PM
    Norsemanvike
    Escondido, CA
    Mine was a custom order too and took the same amount of time.
    Lucifer1 likes this.
  13. Oct 28, 2018 at 4:45 PM
    CementedTaco
    CementedTaco Well-Known Member
    J.
    Usually in the woods
    2018 Tacoma Cement TRD OR 4x4 Tech + Premium
    No tire shine, no wash, blinker change and no dealership sticker.
  14. Oct 28, 2018 at 5:24 PM
    ICU1
    Check for rear bumper/bed alignment
  15. Oct 28, 2018 at 5:28 PM
    jetspeed
    MD
    I -heard- with the 2019's you do not have to grease the prop shaft any longer. Or maybe the rears have been deleted? I could very well be wrong. Anyone confirm????
  16. Oct 29, 2018 at 11:58 AM
    dspec
    dspec Well-Known Member
    Don't have them wash it or put tire shine on either unless you want shit splatted everywhere and small swirl/scratches on the paint.
  17. Oct 29, 2018 at 12:24 PM
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    I know Manuel, excellent waiter
  18. Oct 29, 2018 at 12:31 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Tell them, I'll take a cup of Hot Chocolate please! :burp:
  19. Oct 29, 2018 at 12:44 PM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Dealer decal on the tailgate. That was the one thing that I forgot to mention. Also tell them not to detail the interior, my gauge cluster is scratched because of this.
  20. Oct 29, 2018 at 12:51 PM
    AlabamaBlackSnake
    Jim
    No way to keep that soft cheap Chinese plastic from scratching
