Picking up the new travel trailer tomorrow. What am I missing?
Discussion in 'Towing' started by BigHeadTaco, May 14, 2014.
  1. May 14, 2014 at 3:12 PM
    BigHeadTaco
    BigHeadTaco [OP] GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Trailer specs below, trailer does have tandem axles. I will have an equalizer hitch and brake controller.
    Currently sitting on full OME suspension. Any other suggestions for safety while towing???
    Thanks in advance!
    Unloaded Vehicle Weight (lbs) 3,355
    Dry Hitch Weight (lbs) 443
    Gross Vehicle Weight Rating (lbs) 4,475
    Cargo Carrying Capacity (lbs) 1,120
    Exterior Length 20' 7"
    Exterior Width 96"
  2. May 14, 2014 at 5:47 PM
    BigHeadTaco
    Big Head
    Guess I'm good...lol
  3. May 14, 2014 at 6:27 PM
    BigHeadTaco
    Big Head
    Going camping Friday. I'm hoping my Dakar leaf springs are hefty enough not to sag a lot.
  4. May 15, 2014 at 8:53 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    Dakars will work great. I have a progressive 3 leaf AAL and with my equalizer hitch, my rear doesn't sag at all (and my rig is slightly heavier than yours). Dakars will go on once these wear out. I would bring a floor jack and 4 way also, in case of a flat.
  5. May 15, 2014 at 11:16 AM
    BigHeadTaco
    Big Head
    Thanks for the tips! I do have the jack ready.
  6. May 15, 2014 at 5:55 PM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    There are countless things you will find that you need for camping.
    First, get a good Watts water pressure regulator, not the cheap 2 inch water regulator that most places pass off as good enough.
    White water hose.
    Upgrade the sewer hose, either completely or at least with the adapters and quick connects that let you connect securely to the sewer/dump station.
    Consider getting a surge protector to protect your trailer's circuit boards from the crappy power supplied at most campground power poles.
    Chocks for the wheels.
    Leveling blocks or 2" X 6" boards to do the same.
    A second set of everything you think you might need to use it without having to raid the house every time you go camping.
    Sometimes it helps to camp at home the first time and keep track of the things you have to go back in the house for...
    That's a start...
  7. May 15, 2014 at 9:22 PM
    52motorhead
    52motorhead Well-Known Member
    Pen and note pad. As you think of things write it down and after a couple of trips you will be set.
  8. May 17, 2014 at 6:03 PM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    Is your trailer a double or single axle? IF its a double axle, you won't need a jack. Just pull the good tire up on a block of wood to raise the tire that needs changing.
  9. May 21, 2014 at 7:02 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    Dead battery suck. I would bring a battery charger and a generator if yours doesn't come with one.
  10. May 21, 2014 at 9:08 AM
    BigHeadTaco
    Big Head
    Pulled the new trailer this past weekend. The Tacoma did well, you definitely know that it is behind you. Averaged about 10MPG
  11. May 21, 2014 at 9:18 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Does your Tacoma have the tow package?
  12. Jul 20, 2014 at 8:42 AM
    SOCO Taco
    SOCO Taco Well-Known Member
    BSR
    Pueblo County
    `16, SW, DBL, Short, 4X TRD Off Road
    Do you have a load leveler/sway control on the hitch? If you didn't experience any issues then you're probably good. I hope to pick up a highwall pop up this weekend, do an axle flip on the single axle. Will get a load/sway unit for the single axle. I almost flipped a Wrangler and 5X8 enclosed on I-70. Wasn't going over 60 and that thing was bouncing all over the road, lifting tires. Pucker factor 10+. Sure the short wheelbase had a lot to do with it, sure the taco wouldn't notice. But a few hundred bucks is cheap when considering truck/trailer/gear/people.
