Picking wheels and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Whitetailhunter5, Jan 15, 2017.
  1. Jan 15, 2017 at 3:50 PM
    Whitetailhunter5
    Whitetailhunter5 [OP] Member
    Jon
    2005 Toyota Tacoma TRD Offroad 4x4
    3 inch leveling kit, 50 inch light bar, mesh grill with light bar, bull guard with 2 6inch kc lights
  2. Jan 15, 2017 at 4:05 PM
    Doublecross
    Doublecross Well-Known Member
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    i believe they should fit no problem
  3. Jan 15, 2017 at 4:19 PM
    Tiedie
    Tiedie Well-Known Member
    Way Far Out Yonder
    09 4X4 V6
    Debadged, 4x4 illuminated switch, Redlinegoods console cover,aftermarket outside thermometer.foglight on anytime mod. Double USB charger in dash installed, Ballistic Jesters 16x8. BlavkVue DR 590 Dash Cam
    Dude call them that is where I bought my Ballistic Jesters. You need to check hub bore and lug. Then if you buy check fitment before you mount tires to make sure they dont rub within the 1st 30 days. They were great for me.
  4. Jan 15, 2017 at 4:28 PM
    Whitetailhunter5
    Jon
    Will those wheels be a little wider stance or will they stay in the wheel well I'm looking for a wider stance
  5. Jan 15, 2017 at 4:33 PM
    Tiedie
    Way Far Out Yonder
    09 4X4 V6
    What size do you have on now mine came with steelies 16x7 went with 16x8 and yes I have a wider stance.
  6. Jan 15, 2017 at 4:34 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall Modified bed extender
    This may help
  7. Jan 15, 2017 at 4:39 PM
    Whitetailhunter5
    Jon
    Yeah that helps a lot thanks I think I should go for a wheel that is 17x8 not 17x9
    303tacoma likes this.
  8. Jan 15, 2017 at 4:44 PM
    303tacoma
    Rebecca
    2008 TRD AC
  9. Jan 15, 2017 at 4:46 PM
    Whitetailhunter5
    Jon
    So if the backspacing is higher then you can have a positive offset?
  10. Jan 15, 2017 at 4:51 PM
    303tacoma
    Rebecca
    2008 TRD AC
    Well the way I'm reading it @ +25
    On a 8.5 rim that's a 5.75 b/S
    I'd shoot for less b/S 4.25 if you want your tire to stick out more
    I believe that a 5.75 bs is more bs than stock
  11. Jan 15, 2017 at 4:56 PM
    Whitetailhunter5
    Jon
    Thats what I heard the best backspacing to go with is 4.5" but I can find any wheels i like with the offset of -12mm the ones I really like are these Look at this on eBay http://www.ebay.com/itm/182006326297
  12. Jan 15, 2017 at 5:01 PM
    303tacoma
    Rebecca
    2008 TRD AC
    Well those are a 8"width with 0 offset which is a 4.5 bs according to the chart
    Which is a better fit than the 1st ones
  13. Jan 15, 2017 at 5:03 PM
    Whitetailhunter5
    Jon
    Now would that give me a wider stance similar to the other ones
  14. Jan 15, 2017 at 5:04 PM
    Tiedie
    Way Far Out Yonder
    09 4X4 V6
    I can't say it enough call them, ask seller questions, and if you buy do try them on before mounting tires. After mounting tires they become used rims.
  15. Jan 15, 2017 at 5:06 PM
    Whitetailhunter5
    Jon
    Thats true thanks for the information tho you were a huge help:cheers:
  16. Jan 15, 2017 at 5:08 PM
    303tacoma
    Rebecca
    2008 TRD AC
    :bikewheelie2:The higher the bs the closer the rim is to your suspension..
    So your stock wheels are 16x7 offset +30 which is a b/S right around 5.25
    I wouldn't do a b/S any higher that that for sure
    No problem:cheers:
  17. Jan 15, 2017 at 5:15 PM
    303tacoma
    Rebecca
    2008 TRD AC
    The second ones will give wider stance because of smaller bs
    Use the will they fit calculator
    It will show the difference of where your original rim sits and your new rim choice..
  18. Jan 15, 2017 at 5:16 PM
    Whitetailhunter5
    Jon
  19. Jan 15, 2017 at 5:19 PM
    303tacoma
    Rebecca
    2008 TRD AC
    9" width -12 is a 4.5 bs
    Wider rim is all
    You have to keep in mind your tire size and rim width
  20. Jan 15, 2017 at 5:22 PM
    Whitetailhunter5
    Jon
    So the one with -12mm is little bit wider than the one with 0 offset
