Pics of 265/70/17 Tires w/ 2inches or less lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaGus, Oct 31, 2011.
  1. Nov 9, 2011 at 5:36 AM
    #61
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wow... People are just trying to help you, you're running a tire way too narrow for the rims they're mounted on. If you're comfortable with it, fine be on your way but I'd personally be pretty upset if a tire shop went against a manufacturer's recommendations, didn't tell me and only told me I'd be fine. If those tires ever do fail, you'll be the one stuck holding the bag. I promise you Goodyear will void any warranty once they find out they're not mounted on the correct size rims.
  2. Nov 9, 2011 at 5:39 AM
    #62
    InfamousTonyTaco7714
    InfamousTonyTaco7714 Well-Known Member
    Lucas
    Wilkes, NC
    09 SR5 DCSB 4x4 Timberland Mica
    Borla Catback, 6 inch Pro Comp Stage 1 17x9 Matte Black XD Revolvers, 285/70/17 Radar Renegade R7, Pioneer Double Din, Iron Cross Side Steps, Tactical Armor Group Front Bumper, ARE MX series camper shell, Geared 4.10
    If you would have read my post i said IM TAKING IT TO THE TIRE PLACE TODAY. So its pretty obvious im not just gonna ride around with tires on a rim to wide.
  3. Nov 9, 2011 at 5:40 AM
    #63
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    :rolleyes: They obviously don't know the FACTS that I have stated about this particular tire size/whel size combo. So clearly they do not.
    When you take it back ask them why they ignored the recommended rim size by 2".
    Thanks for stating the shop's name so that people on here know to avoid them.
    I'm concerned for the safety of those riding in your vehicle. With the rims being that wide, the bead is being stretched and weakened.
    Here is it, directly from the goodyear website:
    Tire Size Description Sidewall Approved Rim Width Meas. Rim Width
    LT245/70R17 119R OWL 6.5-8.0 7.00
  4. Nov 9, 2011 at 5:45 AM
    #64
    Lucas
    Wilkes, NC
    LT245/70R17 119R OWL 6.5-8.0 7.00[/QUOTE]
    Well im taking my pickup today and asking them why the ignored that. To be honest, they had a 265-70 goin on there and then randomly went into this like panic over those not fitting so he took the only tire he had(the 245-70) and threw it on there. Me, not knowing much about tires, thought that was fine.
  5. Nov 9, 2011 at 6:03 AM
    #65
    TexasTacoma37
    Well im taking my pickup today and asking them why the ignored that. To be honest, they had a 265-70 goin on there and then randomly went into this like panic over those not fitting so he took the only tire he had(the 245-70) and threw it on there. Me, not knowing much about tires, thought that was fine.[/QUOTE]
    Even then 265/70/17's arent approved for 9" wide rims. They are really designed for 285's to 305's. I wish you luck at the tire place.
    http://www.goodyear.com/en-US/tires/wrangler-sr-a#
    Click on "View tires sizes and specifications" on the left side on the link above.
  6. Nov 9, 2011 at 6:10 AM
    #66
    Lucas
    Wilkes, NC
    Well i was going to get the BFG Rugged Terrain in the 265 tire and its approved for 7-9 inch. So hopefully everything will work out. You wouldnt happen to know what backspacing and offset i need for the 17x9 wheel and 265 tire not to rub anywhere, would you?
  7. Nov 9, 2011 at 6:13 AM
    #67
    Pugga
    Massachusetts
    Those are nice looking tires. If you get them post up what you think of them. I don't think many people have them.
  8. Nov 9, 2011 at 6:16 AM
    #68
    Lucas
    Wilkes, NC
    Im really wanting them, i like the agressive look, but theyre not overly aggresive.
  9. Nov 9, 2011 at 6:26 AM
    #69
    TexasTacoma37
    Between 4.5" and 5.5" backspacing will get the job done. The offset varies depending on rim width and backspacing. Just focus on the backspacing number.
  10. Nov 9, 2011 at 6:36 AM
    #70
    TexasTacoma37
    It looks like your Revolvers have 4.5" backspacing, because that's the only specs the 17x9's come in. Do you know exactly what you are rubbing on? Some have a minor rub on the mudflaps running 265/70/17's.
    I'm running 265's on a 9" wide wheel with 5.4" backspacing with no rub.
  11. Nov 9, 2011 at 6:46 AM
    #71
    Lucas
    Wilkes, NC
    Alright, preciate the help here. I just want to get the wheels right. Ive also heard that a 4.5 backspacing and -12mm offset is the best for our pickups? Am i right or did i hear wrong?
  12. Nov 9, 2011 at 6:51 AM
    #72
    TexasTacoma37
    Folks call 4.5" backspacing the "best" for our trucks because it allows you to run either a 265 on stock suspension, or a 285 with a 3" lift. So it's a "one size fits all" kind of wheel.
    The -12 offset simply means that it is a 9" wide wheel. (A wheel with -12mm offset that is 9" wide has 4.5" backspacing by definition).
  13. Nov 9, 2011 at 7:08 AM
    #73
    Lucas
    Wilkes, NC
    Well im thinking the backspacing they put on my pickup isnt right, because if you're supposed to be able to run a 265 then my 245 shouldnt be anywhere close to rubbing.
  14. Nov 9, 2011 at 7:18 AM
    #74
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They are stainless Nfabs , they aren't currently on the truck
  15. Nov 9, 2011 at 7:34 AM
    #75
    TexasTacoma37
    Yeah that's why I was asking if you knew what exactly it is rubbing on. If it's the mudflaps, that happens sometimes and you might have to lose them.
    At this point with the 245 being quite a bit skinnier than the wheel itsself, the wheel is stretching the 245 out and causing it to rub. I bet you wouldn't have any worse rubbing with the 265 than with the 245.
  16. Nov 9, 2011 at 7:58 AM
    #76
    Lucas
    Wilkes, NC
    I was wanting to put the 265s on there and then take the flaps off. But it seems like they just won't agree and say they will rub too much but hopefully i can get somewhere today.
  17. Nov 9, 2011 at 8:04 AM
    #77
    TexasTacoma37
    I would take the flaps off before you go there, just so that if that's the issue they won't give you a hard time about it.
  18. Nov 9, 2011 at 8:09 AM
    #78
    Lucas
    Wilkes, NC
    Good idea. Mind telling me how to remove them?
  19. Nov 9, 2011 at 8:16 AM
    #79
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    I wanna get some like it but the black ones
  20. Nov 12, 2011 at 11:39 AM
    #80
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    17x8 with 4.1" BS
    Tires are General Grabber AT2 265/70/17 and only rub on the mudflaps which will coming off. I am on Toytec/Eibach springs and bilsteins set at zero (1.6") in the front and TSB in the back
