Pics of 285/70/16 please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacific_roots, Oct 30, 2015.
  1. Oct 30, 2015 at 12:54 PM
    Pacific_roots
    Pacific_roots [OP] John 3:16
    Josh
    Big Island, hawaii
    MGM 2015 dcsb trdoffroad
    Anybody running 285/70/16???? Can't find pics anywhere here. Thanks
  2. Oct 30, 2015 at 5:02 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Most people running a 285 on a 16" wheel have 285/75r16. 70 series tires are a 33" tire on 17" wheels.
  3. Oct 30, 2015 at 5:11 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    You're going to have a hell of a time trying to find a tire in 285/70/16. A more common size is 285/75/16.
  4. Oct 30, 2015 at 5:25 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    I found a nitto trail grappler in a 285/70/16 on Amazon, they've been carrying them for awhile now. Comes out to be a 31.7x11.3
  5. Oct 30, 2015 at 5:27 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    I just don't wanna have to do any cmc or wheel well trimming on my brand new taco
  6. Oct 30, 2015 at 5:33 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Its funny you mentioned the Nitto Trail Grappler in 285/70/16. Out of curiosity when I first read the tire size you posted, that tire was only one in that size I could find on Tire Rack, Discount Tire, and Amazon. So unless you want that specific tire, I will echo what I said before.
  7. Oct 30, 2015 at 5:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ^ then stick with 265/75R16's
    agunday21 and PVT Pablo like this.
  8. Oct 30, 2015 at 5:44 PM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    That size is pretty much the same as a 265/75, just a little wider, like half an inch. There's more choices in the 265. But it's your truck
  9. Oct 30, 2015 at 5:52 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    I'm gonna go with the trail grapplers, had them on my 2003 tundra and loved em. Just wanting to see if they look small in a 285 70 16 on a 3 inch lifted tacoma
  10. Oct 30, 2015 at 5:53 PM
    Pacific_roots
    Josh
    Big Island, hawaii
  11. Oct 30, 2015 at 5:57 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    I'd love the little bit wider, had 265/75/16 on my last 3Rd gen 4runner and they looked a little skinny with a 3 inch lift, but still would be better than my stock size now
  12. Oct 30, 2015 at 5:59 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    Do you guys know if they would work on a 16x8 rim with 4.5 backspace without having to add spacers? Thanks for the reply's
  13. Oct 30, 2015 at 6:04 PM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    Not sure on that because I'm stock with 265s but it shouldn't. Someone else will have to answer that one
  14. Oct 30, 2015 at 6:04 PM
    nd4spdbh
    SoCal
    your only guarantee is that 265/75R16's will work on stock offset and sized rims... beyond that it may or may not work.
    IMO 8in wide is too wide for a 265. its nice to have some bulge to protect the rims and not pop a bead.
  15. Oct 30, 2015 at 6:09 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    From everything I've observed on trucks I work on for other folks, the issues that result in tire rub are as much, if not MORE to do with tire width than with tire height. With either wheel spacers OR offset wheels, when you move the tire away from rubbing the upper control arms, you end up with a wider arc when wheels are turned...and closer to the cab mount when at full lock turn.
    I've got 265/75/r16 Duratracs on my 2011 Tacoma. Front end is lifted 2-5/8" above what it was stock. Then I used 1" Bora wheel spacers. Wheels are stock TRD Off Road 16". These tires cleared with flying colors in stock trim. When I lifted it, the tires cleared even better. Then I put the spacers on to get a better stance (and to clear 285/75/r16's if I decided to go that route) Once I had the spacers on, the 265's come very close to the cab mount. They don't rub, and I can't make 'em rub....but they're close. Wider tires need either offset wheels or spacers to clear UCA's. IMHO, you won't make any significant clearance gain by using a 285/70/r16.....
  16. Oct 30, 2015 at 6:21 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    Ok so you think I'd have to trim with that tire wheel combo then?
  17. Oct 30, 2015 at 6:22 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    I also had a 275/70/17 tire in mind
  18. Oct 30, 2015 at 6:25 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    It's possible they won't rub if you stay on flat parking lots, etc....But, If you take it off road or do anything that'll flex the suspension, and you ever happen to have the front wheels turned to full lock, I think you're gonna rub the cab mount. Just my opinion though. Hopefully someone here has the same exact combination and can tell you for certain.
  19. Oct 30, 2015 at 6:27 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    Ok thanks for the advice much appreciated
  20. Oct 30, 2015 at 6:37 PM
    Pacific_roots
    Josh
    Big Island, hawaii
    Hmmm ok I never thought of the blow out issue. Maybe I'll go with the 275/70/17 after all. Thanks! Now to find the right wheel, I was gonna get the method standards 16x8 hopefully they make it in a 17"
    Blackout14 likes this.
