PICS of any or all Cast iron or Dutch Ovens Go here. Post them UP
Discussion in 'Food Talk' started by taco084gb, Jun 10, 2010.
  1. May 11, 2019 at 9:21 PM
    #241
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    For those of you with cast iron skillets...how do you clean them? I recently got one, seasoned it per instructions (coated with oil, set upside down in oven on high temp for a period of time). I have used it twice since them, both times cooking some skirt steak for carne asada....I can't really get it clean though. I heard you shouldn't use soap to clean it. So I use a sponge (both soft and rough side) rubbing aggressively with water and just pat it dry with a paper towel. Its not really "clean" thoroughly though, maybe that's ok.... are you supposed to let it cool before you clean it? Or is hot ok? Any tips??
  2. May 11, 2019 at 10:20 PM
    #242
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    boil wate
    Boil water in it and scrape with a metal spatula then dump, repeat if necessary, hit with non soapy sponge if necessary or scrub with coarse salt. Wipe out with a paper towel, re-oil and wipe some more while pan is hot/warm put away. I clean the outside with soap and water if it gets real greasy or something. Some foods are easier to clean than others. As the seasoning builds over time they get easier to clean. I haven't tried it but they sell this product made specifically for cleaning cast iron that looks like chain mail, I'm curious about it. Its not gonna be spic and span like your other pans, that's kind of the beauty of it. On a side note, once broken in these handle covers are sweet!
    https://www.amazon.com/Panhandle-Potholder-Stitched-Hide-Drink/dp/B017M7VG5G/ref=sr_1_8?crid=8H9E57PL3CCM&keywords=cast+iron+handle+cover&qid=1557638331&s=gateway&sprefix=cast+iron+%2Caps%2C175&sr=8-8
    wilcam47 and Shwaa[QUOTED] like this.
  3. May 12, 2019 at 8:48 AM
    #243
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    There are a lot of ways to clean it. My favorites are:
    Wipe with a paper towel.
    While hot rinse with hot water and a brush. (I usually do this at home).
    Do not ever use soap or acid based dishes, unless you want to season it again.
    I only heat the oven to 350° and keep it in there an hour, upside-down, on the heat, then let it cool enough to do it again. 3 times at least. Flax oil.
    I caramelize onions or fry potatoes to season more.
    Iron is very porous, so it will take much time to fill those little holes.
    How clean do you want it? Enough to remove the seasoning?
    Wipe with paper towel, and use again, soon. Or wash with hot water if you are not going to use it soon.
  4. May 12, 2019 at 7:56 PM
    #244
    la0d0g
    running for the hills
    For crawling not hauling
    Start over. Take a flap disc on an angle grinder and clear out all the shit they put on them from the factory. Once your at silver and smooth, do the seasoning method about five times. Takes about a day. Then the next day cook a pack of bacon. Then you'll be ready to go, just wipe out whatever you cooked with a paper towel.
  5. May 12, 2019 at 8:05 PM
    #245
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    and the lid makes awesome pizza
    wilcam47 likes this.
  6. May 16, 2019 at 10:05 AM
    #246
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    2016 White Tacoma TRD OR AT 4x2 DCSB
    Faux pro grille, hood bracket mounted ditch pods, gator trifold tonneau cover
    A few weeks ago, we were at my fiancee's brother's farm for something or other and they had this stack of cast iron pans rusting outside. I offered to clean and season them and in return I'd get a pick of the litter. I'm wishing I looked at the rest of them to know what they were, but the top one was a large logo griswold and that's enough to get anyone excited for a free skillet in exchange for manual labor.
    In the darkness trying to get home, I completely forgot the pans, and they forgot them when they came down to our place for mother's day. I'll share pictures once the pans make it down here. I'm debating what method to use for removing rust, drill & wire brush or angle grinder with a flap disc, or the oven cleaner in a paper bag.
    wilcam47 and Kanyon71 like this.
  7. May 16, 2019 at 1:27 PM
    #247
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    wow sad and great at the same time!
  8. May 16, 2019 at 1:36 PM
    #248
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I've never done it, but it looks easy. electrolysis rust removal
    https://www.google.com/search?newwi....gws-wiz.......0i71j0i67j0i131i67.fUB1aMA6G4U
  9. May 16, 2019 at 1:39 PM
    #249
    wilcam47
    Will
    Bourbon state
    doesnt vinegar work also?
  10. May 16, 2019 at 2:21 PM
    #250
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    I think it might? I live in an apartment, so the electrolysis method is one that requires a bit more equipment than I have at home.
    CurtB and wilcam47[QUOTED] like this.
  11. May 19, 2019 at 10:13 AM
    #251
    Shwaa
    Bay Area, CA
    So I bought "The Ringer" and cleaned the pan well with hot water, and it is smooth all around...there are these burnt spots though (see picture). I have only used this pan twice and I think I used it the wrong way (too hot?), then let it sit and didn't clean it well initially. Do you suggest I try and get that burnt stuff off somehow? Or is it ok to just leave it as is? I scrubbed pretty aggressively with The Ringer and that got most everything off except that caked on stuff. I re-oiled the pan afterwards
    Thanks!
  12. May 19, 2019 at 4:21 PM
    #252
    HighCountryTacoma
    Colorado
    It's fine. Unless food is getting hung up on it I wouldn't worry too much about it. Cast Iron evolves, ages and seasons over time. Its like a baseball glove once broken in It'll probably look uglier but perform better.
  13. May 19, 2019 at 4:37 PM
    #253
    HighCountryTacoma
    Colorado
    Choco_Taco, czach and Shwaa like this.
  14. May 19, 2019 at 4:41 PM
    #254
    HighCountryTacoma
    Colorado
    Also like @la0d0g said if you want to get the lodge pans super slick, taking a grinder to it may be necessary. It'll get rid of all that speckled shit. Wear a mask and glasses if you go this route.
    wilcam47, CurtB, Shwaa and 1 other person like this.
  15. May 19, 2019 at 5:03 PM
    #255
    Shwaa
    Bay Area, CA
    Good video, thank you for sending that along!
  16. May 19, 2019 at 6:53 PM
    #256
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    So my fiancée's bother brought over the cast iron, I collected the two Griswold pans for now for restoration. A third was unmarked and I might do this one at a later date, but it's a low walled skillet which is a little odd.
    But they've certainly become more rusty since I remembered them and I'm wondering if I'm in over my head. I'm thinking to go the vinegar bath route and working on these two over memorial day weekend.
    16409710-6254-421F-9C77-E6CC73D2FBEE.jpg 13E19E30-30A3-40AD-99B1-10B61CAE7ECE.jpg C8B45E8A-B1F9-4CB5-9105-FAB8E960066C.jpg AFE762A4-C061-40DA-8A38-45DCB1FD869E.jpg
    truchador, wilcam47 and yota243 like this.
  17. May 19, 2019 at 7:22 PM
    #257
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    If you have a battery charger, look up electrolysis on YouTube.
    czach[QUOTED] likes this.
  18. May 19, 2019 at 7:27 PM
    #258
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    It might be older looking at it. It has the slant logo and is marked without the EPU. It might put it into the 1880-1907 period.
  19. May 19, 2019 at 7:28 PM
    #259
    czach
    czach ლ(ಠ益ಠლ)
    Zach
    Alameda, CA
    I don't unfortunately. Though there is ample parking at the apartment i'm in, unfortunately, I don't really have a storage/workshop space to keep extra stuff.
  20. May 19, 2019 at 8:19 PM
    #260
    Shwaa
    Bay Area, CA
    Just out of curiosity are you supposed to get rid of all that speckled shit? I figured the pan was made that way for a reason, but I do see lots of "smooth" cast iron pans in this thread as well. Maybe it's just a preference thing. As you can tell I am totally new to this stuff. Actually my GF got this pan 3 years ago as a gift and it has never been used until a cpl weeks ago, sad to say. I finally broke it out. I think I am going to like it, other than being heavy as shit (i.e. i cant lift it and scoop food out as easily as a non-stick pan)
    czach and wilcam47 like this.
