PICS of any or all Cast iron or Dutch Ovens Go here. Post them UP
Discussion in 'Food Talk' started by taco084gb, Jun 10, 2010.
  1. Sep 18, 2019 at 3:20 PM
    #401
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Nice score man!
  2. Sep 18, 2019 at 3:42 PM
    #402
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    nice! Any name brands that you noticed?
    Bigdaddy4760[QUOTED] likes this.
  3. Sep 18, 2019 at 3:46 PM
    #403
    Bigdaddy4760
    Maner
    Poolville Texas
    Never looked just chunked them in the shop. When I get time will look them over.
    wilcam47[QUOTED] likes this.
  4. Sep 18, 2019 at 4:27 PM
    #404
    la0d0g
    running for the hills
    For crawling not hauling
    Damn! Lucky!
  5. Sep 30, 2019 at 10:27 AM
    #405
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    la0d0g and wilcam47 like this.
  6. Nov 11, 2019 at 6:40 AM
    #406
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    I’m coming in a bit late to this, but why sand down the cooking surface? I bought a Lodge skillet a while ago, but haven’t really used it as much as I thought I would but would like to use it more, so I’m curious about this method.
  7. Nov 11, 2019 at 6:56 AM
    #407
    yota243
    E.J.
    north Alabama
    Because it isn't smooth; a smooth surface lends itself better to a non stick since there is less crevices for food to seep into
    Also
    https://youtu.be/IRmHtp1TEnw
  8. Nov 11, 2019 at 7:49 AM
    #408
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    What he said ^^
    Bigdaddy4760, Cold Iron and yota243 like this.
  9. Nov 11, 2019 at 8:57 AM
    #409
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I prefer the older Griswold and Wagner skillets for that very reason. I use a 3M rust stripping wheel on my drill if I pick up a Lodge cheap enough
    Gasser comes in handy to start the reseasoning
    Then finish seasoning with bacon. Bacon, lots and often.
    Of course that is home made and smoked bacon.
  10. Nov 11, 2019 at 9:31 AM
    #410
    Choco_Taco
    Tim
    Fredericksburg, VA
    What do you do after the bacon? Wipe off with water and paper towel, then add some Crisco and let cool? That’s what I was shown, but not sure if that’s right.
  11. Nov 11, 2019 at 12:12 PM
    #411
    Cold Iron
    Mn.
    2013 AC T|X Baja
    That should work.
    With bacon first thing I do while the pan is still hot is pour the grease in a bacon grease catcher that I keep in the fridge. Because all great recipes start with first you cook a pound of bacon...
    It has a strainer that sits on top which is removed here.
    Right before I get ready to do that I turn on the kitchen faucet to pure hot then stick the pan under it. I have a stiff nylon bristle brush I keep on the counter and scrub it out well. Then throw it back on the burner which is turned off but still hot and dries the pan in seconds. After that you can use Crisco or what ever you want, eventually it will turn black and be seasoned enough you don't usually have to keep seasoning it. If I end up with something in it that sticks first I use a hard silicone scrapper to get the chunks out. Failing that I use a stainless steel chainmail scrubber.
  12. Nov 11, 2019 at 12:20 PM
    #412
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
  13. Nov 11, 2019 at 1:13 PM
    #413
    Cold Iron
    Mn.
    2013 AC T|X Baja
    wilcam47 and Bigdaddy4760 like this.
  14. Nov 25, 2019 at 2:15 PM
    #414
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Interesting, all the things you all do to season.
    I just use them, they season themselves.
    I have used flax, but that gets removed over time.
    I use olive oil daily. I use an old metal spatula, it does a good job of scraping as I use it.
    Rinse with water only, no soap ever, my pans are flat bottom, no holes.
    wilcam47 likes this.
  15. Nov 25, 2019 at 2:30 PM
    #415
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I use Crisco to season my cast iron after using it. My routine is this...After I finish cooking, I scrape the surface of the skillet with a small Winco spatula, then let cool. Next, I rinse with HOT water. Most everything comes off at this point. Then I wipe dry with a paper towel and head for the cooktop. I put skillet on med heat to dry thoroughly. When it is hot, I wipe it with a paper towel and a little Crisco. When it starts to smoke, just a little, I turn the fire off.
    It sounds complicated and long, but it's not hard at all and takes minutes. Mine are well seasoned because I use a cast iron skillet at least 4-5 times a week. It also helps to start with a good skillet. Field Company skillets are the best that I have ever bought. Wouldn't even consider a Lodge (or the like) if I needed a new one.
    INBONESTRYKER likes this.
  16. Nov 25, 2019 at 3:06 PM
    #416
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    o_O
  17. Nov 25, 2019 at 3:11 PM
    #417
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    If, for some reason, I needed a new cast iron skillet...no, wouldn't even consider a Lodge. Field Company skillets are WAY better in every way. A cast iron skillet is generally a 1-time purchase, so buy a good one.
    Hobbs and wilcam47 like this.
  18. Nov 25, 2019 at 3:18 PM
    #418
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I use my cast all the time. even for biscuits...
    yota243, la0d0g, 2Toyotas and 2 others like this.
  19. Nov 25, 2019 at 3:22 PM
    #419
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Way better? $160 better for 12"? Convince me. I know Lodge is not the best, but after a little work my Lodges have worked well for me.
    Tacotsubo and wilcam47 like this.
  20. Nov 25, 2019 at 3:23 PM
    #420
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Time and temp? ;)
