Pics of brake controller placement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cummins, Dec 28, 2010.
  1. Dec 28, 2010 at 1:05 PM
    Cummins
    Cummins [OP] Well-Known Member
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    I am going to put a brake controller in my truck and was wondering where you all mounted yours. I mounted them on the right side of steering wheel on my other trucks but did not know if you all placed them in different spots.
    Thanks,
    Robert
  2. Dec 28, 2010 at 2:53 PM
    Mike27t
    Mike27t Well-Known Member
    Was planning on placing it under the steering wheel as well but I ddint want to take the limited knee space I had. So I ended up mounting it here. Still have use of the cup holder (not that we run short of those).
  3. Dec 28, 2010 at 3:16 PM
    Cummins
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    I was looking at that today and due to the same reason did not want to lose leg room. Thanks and how did you run your wires.
    Robert
  4. Dec 28, 2010 at 7:52 PM
    Mike27t
    The cup holder base pops out. Once out I made a slit in the plastic the cup holder sits in and ran the wire through. Once the cup holder is placed back into its spot you cant see the wires coming through cause the brake control blocks the view.
    Im going to do more work on the truck this weekend, if you would like I can take a detailed pic of what I described above.
  5. Dec 29, 2010 at 9:43 AM
    Cummins
    Robert
    Winchester, Ky
    05 Tacoma SR5 TRD
    That would be great Thanks
