pics of Leer 100 XR and 100XL caps please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolf13, Oct 6, 2009.
  1. Oct 6, 2009 at 8:21 PM
    wolf13
    wolf13 [OP] Well-Known Member
    IL
    2010 V6 4X4 Access cab TRD OR
    TRD Offroad w/Tow package. LEER 100XQ topper, painted grill surround, 08 cup holders, scangauge II
    I am looking for some pics of Leer 100XR and XL caps, mainly on access cabs or DCLB's. I've noticed on a couple of the pics of the 100XL's I've found that it doesn't seem to blend as well with the body as the XR and XQ and I'd like to see some more pics before I go order anything.
  2. Oct 7, 2009 at 7:35 AM
    Negative1
    Negative1 Well-Known Member
    I have the 100XL and love it... Very high quality cap.
    The lock mechanism is somewhat flimsy though, but it will be replaced under warranty. Cant say enough great things about the cap.
  3. Oct 7, 2009 at 7:43 AM
    wolf13
    IL
    Thanks, yours is actually one of the trucks that got me wondering about the fit on the XL so I am glad you posted. when I look at your pictures, the rear corner looks like it sticks out a lot farther over the truck instead of flush as if the cap was an inch or two too long? or is that just an optical illussion?
    Did you get the windoors with yours?
  4. Oct 7, 2009 at 7:46 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    The 100XL and 100XR models are manufactured from the same molds. The only differences are the rear lock and the side windows. There is no intended difference in the fiberglass, the only difference from one to another is that Leer has multiple of these 100xr/100xl molds.
  5. Oct 7, 2009 at 7:47 AM
    Negative1
    It overhangs a small bit... not even 1"
    It's designed this way to ensure that rain flows over and that nothing get's in the box. I also installed a tailgate seal... Highly recommended.
    I also even took the bed rails off before the cap install and applied silicone to seal the box up good, since I have travelling across Canada and US and sleeping in the back on a Truck Bedz.
    Another great product BTW.
    No windoors on mine, didnt need them. But I did get the 12volt plugs, fold down rear slider as well.
  6. Oct 7, 2009 at 7:50 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    Here is the 100XR
    It's not a bad cap but I feel it was a Friday afternoon build if you know what I mean. I don't think mine is a good representation of all Leer Caps. Mine was supposed to have the "windoors" (?). Those are the side windows that open, as you can see it does not have them. I was told at the truck outfitter place that Leer and the window vendor are in some type of contract dispute and they could not get the windows at the moment. I think they just forgot to put it on the order. Wish I had them!
    Pirhett likes this.
  7. Oct 7, 2009 at 11:28 AM
    09tacomg
    09tacomg Active Member
    USA
    09 DC TRD Sport SW
    Leer 100R
    100 R
  8. Oct 7, 2009 at 6:43 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    My 100R is not quite a perfect blend into the lines of the cab. Fortunately, its a bit smaller than the cab, would really look silly if it were bigger. The roof on the cap is a bit more rounded than the cab.
  9. Mar 12, 2012 at 1:01 PM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
  10. Mar 12, 2012 at 2:51 PM
    mcgiiver
    Princeton, NJ
    Not quite the fit I would like , but acceptable.
  11. Mar 12, 2012 at 3:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What's wrong with the fit ?
  12. Mar 12, 2012 at 4:35 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Looks great from here.
  13. Mar 12, 2012 at 6:40 PM
    OZ-T
    Peter North
    British Columbia
    If it's not what you ordered , I would have refused it .
    In fact , I did refuse my first Leer 100RCC , they had drilled the roof rack feet too close together , front to back , my theory is that they used a template for a shortbox cap , anyway , not what I ordered , not my problem .
    It went back and they sent me a new one , that's too much money to just go , " oh well "
    ready6delta and RNJNKE like this.
  14. May 10, 2012 at 3:58 PM
    Izzapac
    Izzapac Member
    St. Robert, MO
    2007 TRD Sport Silver Streak
    Bilstein 5100s front (1.75") & rear
    How much did the 100XR run you? How easy is it to get one colored coded to my silver streak ext cab?
  15. May 12, 2012 at 5:05 PM
    OZ-T
    Peter North
    British Columbia
    You just order it the factory colour you want
  16. Feb 11, 2013 at 6:22 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Sorry to bump an Old thread but those of you with caps, did you or the installer remove the plastic bed rails? I'm talking the plastic "cap" that protects the metal bed rail.
    Was this removed? If not, what did you do to close the inch gap on the front bed rail closest to the cab?
    Thanks!
  17. Feb 11, 2013 at 6:29 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    No, the plastic bed rails stay on. To cover the gap at the front of the bed I ran two layers of the rubber weatherstripping you can get at HD.
  18. Feb 11, 2013 at 6:51 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Thanks for the quick reply!
    And the weather stripping keeps the water and dust out pretty well?
  19. Mar 5, 2013 at 5:27 PM
    GreeneMan
    GreeneMan En serio?
    Robert
    Asheville, NC
    09 Base 4x4
    Cooper A/T LEER Campershell Shrockworks Front/Winch Fox 2.0 rem. res Front and rear. Icon AAL 3pk
    Just what I needed to hear. We've have some major rian in NC, shnits gettin' wet!
  20. Jul 18, 2015 at 8:30 AM
    scocar
    scocar hypotenoper
    Bump for more pics. Post 'em if you got 'em, and if you don't got 'em, take 'em, then post 'em.
