Pics of non-lifted trucks with 265/70/17 or 265/75/16 size tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Runnerstrom28, Mar 8, 2011.
  1. Feb 26, 2017 at 5:45 PM
    #721
    worm09
    worm09 Well-Known Member
    Robert
    Old Fort NC
    do you rub any with the 17x9 set up? and are you running a back spacing?
  2. Apr 10, 2017 at 10:17 PM
    #722
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    2013 Tacoma AC 4x4 M/T 2.7L
    Cooper Discoverer S/T MAXX 265/75/16
    BassAckwards and skrazz like this.
  3. Apr 11, 2017 at 9:37 PM
    #723
    LG Taco
    LG Taco Well-Known Member
    image.jpg Duratracs 265/75/16
    BizzyB726 and o0oSHADOWo0o like this.
  4. Apr 14, 2017 at 2:46 PM
    #724
    kappy079
    kappy079 Member
    Kevin
    Virginia Beach
    2015 TACOMA SR5 4x4 ACLB
    Did you have any issues clearing the calipers with the wheel?
  5. Apr 14, 2017 at 11:59 PM
    #725
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    Bellingham & Long Beach?! Are you my double?
  6. Apr 20, 2017 at 12:59 PM
    #726
    Matt89
    Matt89 Member
    Matthew
    2013 Black Tacoma Texas Edition
    Swapped out my TX Edition Rims and BFG Rugged Terrains for ATX Mojave 2 Rims and BFG KO2s at P265/70/r17. I did have to remove the small front mud flaps and went ahead and removed the rest.
    o0oSHADOWo0o likes this.
  7. Apr 20, 2017 at 1:02 PM
    #727
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    265/75/16 on stock suspension. Michelin LTX A/T2
  8. Apr 24, 2017 at 7:40 PM
    #728
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    265/75/16 Toyo Open Country A/T 2 with level kit
    bigfoote13 and o0oSHADOWo0o like this.
  9. Apr 29, 2017 at 11:13 AM
    #729
    Scribbles
    Scribbles Well-Known Member
    LoUiSiAna
    2010 SR5 PreRunner
    None yet
    Finally got these installed, lift to follow.
    BF Goodrich ATK02 265-75-16
    on T-Force wheels
    Valpo likes this.
  10. May 2, 2017 at 7:50 PM
    #730
    nway2deep
    nway2deep Well-Known Member
    Shawn
    Mississippi Gulf Coast
    2017 Access Cab Manual TRD Sport
    TRD SEMA Wheels, BFG KO2 265/70/17,Meso Turn signals, Meso maps and Dome,
    IMG_20170502_191213.jpg IMG_20170502_191228.jpg IMG_20170502_191251.jpg IMG_20170502_191319.jpg No rubbing anywhere Awesome
  11. May 2, 2017 at 8:44 PM
    #731
    nway2deep
    Shawn
    BFG KO2 265/70/R17
  12. May 15, 2017 at 6:49 PM
    #732
    Trkrunner
    Trkrunner Member
    2013 Tacoma TDR sport
    Debating on running the Nitto Grapler 265/70r17 with some Pro Comp wheels. Question,
    Pro comp 5001, 17x9, offset: 6.6, backspace:4.75
    Or should I run 17x8, offset: 0, backspace: 4.5
    Anyone see any issue with either of these set ups with 265/70 17?
    Thanks
  13. Jul 26, 2017 at 9:43 AM
    #733
    iiiDontTRY
    iiiDontTRY Member
    Jaeckel
    Texas
    2013 Prerunner DoubleCab V6
    Bull Bar, Carvern R Exhaust, 5100 Bilstein 0", OEM 885 coils, 1.5" AAL, Kendwood Amp and Dual Subs
    1.75" Bilstein level with 265/65/17, I want to make the change to 265/70, I would go for 275/70 for a beefier look if it wasn't e load
    Scribbles likes this.
  14. Aug 18, 2017 at 5:09 PM
    #734
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    Are my tires (265/75/16) destined to rub if I change wheels?
  15. Aug 19, 2017 at 4:49 AM
    #735
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Pre lift. 265/75/16 -10 offset
    BizzyB726, JDB02, tinker_troy and 3 others like this.
  16. Aug 21, 2017 at 6:59 AM
    #736
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Did they rub any?
  17. Aug 21, 2017 at 7:31 AM
    #737
    3pooches
    VA & WV
    They did only due to the offset. Had to remove the mud flaps but no trimming
    DBTaco[QUOTED] likes this.
  18. Aug 26, 2017 at 8:37 AM
    #738
    burddog
    burddog Active Member
    Ephrata, PA
    2015 prerunner
    American Outlaw Hollywood 17x8.5 -10 offset Bilsein 5100 all around Low Range 1" rear Blocks Hankook Dynapro atm 265/70/17 Shaved badges A little rattle can green on the front. Gator soft bed cover
    American outlaw "hollywood" 17x8.5 -10 offset with Hankook 265/70/17
    Mudflaps off
    Passenger side grazed inside flare. I cut both sides back and inch.
  19. Sep 7, 2017 at 10:41 PM
    #739
    Trkrunner
    Trkrunner Member
    Pro Comp 5001 17x8, 0 Offset 4.5bs
    Tire:Nitto Terra Grapler G2 265/ 70r17
    TacoNC and burddog like this.
  20. Sep 7, 2017 at 10:48 PM
    #740
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Michelin Defenders 265/75r16, rear leaf tsb, stock otherwise.
