Pics of OEM tonneau
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, Oct 30, 2019.
  1. Oct 30, 2019 at 2:14 PM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Can someone post a pic if whatever OEM tonneau cover Toyota offers on the 3rd gen please? Can't seem to find a pic on Toyota website.
  2. Oct 30, 2019 at 3:01 PM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    I'll take a picture for you when I get off work in a few hours.
    TacoTim85[OP] likes this.
  3. Oct 30, 2019 at 3:37 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    32D042AE-FB2D-4C2D-9CA6-E53EFA05A783.jpg B85A6C59-EAF6-4615-8E41-4002FD9039B5.jpg
    What I had on my phone, I can take more this evening if you need.
  4. Oct 30, 2019 at 3:46 PM
    TacoTim85
    Thanks! Does this one fold up? And do they typically stay "locked" if the tailgate is closed and locked?
    You can see I'm a real expert when it comes to tonneau covers.
  5. Oct 30, 2019 at 3:55 PM
    cop414
    Tim
    Central PA
    It folds 2/3 of the way, the last panel by the rear window does not fold. Yes it stays “locked” if the tailgate is closed and locked but not if open. You have to reach under the first panel to release that panel so if the tailgate is closed and locked you’d have to pry it open to break in. Not an actual lock but if you can’t open the tailgate then you can’t access the release.
    You can fold the middle panel by accessing the same type of latch and if you need to drive with it open you fold the two onto the one next to the rear window and there’s two straps that snap into two corresponding holes in the third panel so that they sit somewhat tight while folded.
    It sounds much more complicated than it is.
  6. Oct 30, 2019 at 3:55 PM
    Roadkill1081
    Roadkill1081 Well-Known Member
    Maryland
    2020 DCSB TRD SPORT CEMENT
  7. Oct 30, 2019 at 3:59 PM
    cop414
    Tim
    Central PA
    I forgot all about that video, pretty much covers it all.:wave:Pun intended!
    Bleep100 and TacoTim85[OP] like this.
  8. Oct 30, 2019 at 4:05 PM
    aStrauss
    aStrauss Well-Known Member
    Andrew
    2019 TRD OR DCSB 6MT
    The rear most 1/3 will not stay folded forward on its own. I learned this the hard way on day 5 with my truck...
    Picked up on a Saturday, the following Wednesday morning had my bike in the bed, only the rear-most 1/3 panel folded forward, and it flipped back while on the highway. The end of my handlebar punched right through. I have a strap that I use to hold it down now.
    Bleep100 likes this.
  9. Oct 30, 2019 at 4:08 PM
    Roadkill1081
    Maryland
  10. Oct 30, 2019 at 4:21 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    It’s not supposed to, Thats what the clips are for, to hold it open while driving.
  11. Oct 30, 2019 at 4:22 PM
    aStrauss
    Andrew
    Right, yeah. “Learned the hard way,” remember? Hahah
    I was mainly posting that as a warning.
  12. Oct 30, 2019 at 4:25 PM
    Roadkill1081
    Maryland
    I haven't used mine in the folded position yet, but I don't think there's anything to hold down the first section. You have to fold it twice to be able to use the straps. Or is there?
  13. Oct 30, 2019 at 4:30 PM
    aStrauss
    Andrew
    Nope, nothing. I use a couple of Thule cam straps to strap the last third panel down on top of the center panel if I drive with it that way. But with the center and rear sections both folded forward, there are two slick little buckle straps that hold it all in place.
  14. Oct 30, 2019 at 4:33 PM
    mutely
    yup only on the 2nd section., fold up 2 sections clip it open. Nothing to hold the last section open only.
    The fact that they put them their, I’d have thought was enough to release you need to use them, and that you can’t use them on just the last section means it’s both sections or nothing while driving.
  15. Oct 30, 2019 at 4:41 PM
    aStrauss
    Andrew
    I figured mine would flip forward while driving, wasn’t expecting it to be with enough force to put my handlebar through it.
  16. Oct 30, 2019 at 4:48 PM
    Roadkill1081
    Maryland
    I was once in a car that had its hood open at 45-50Mph and it destroyed the windshield and even bent the front of the roof. The tonneau may be behind the cabin, but from the look of what happened to yours, it gets a pretty good slam even if it's being spared some of the wind.
  17. Oct 30, 2019 at 4:49 PM
    cop414
    Tim
    Central PA
    Damn, that really sucks. Nothing like being the subject of a cautionary tale.
  18. Oct 30, 2019 at 5:09 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Toyota sells replacement pieces for damaged parts at stealership prices.
  19. Oct 30, 2019 at 5:16 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    OEM tri fold soft tonneau, short box.
  20. Oct 30, 2019 at 5:26 PM
    mutely
    Toyota doesn’t make a soft fold cover, so that’s not OEM
    Skidog1 likes this.
