Pics of truck bed topper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by navyrt, Jan 17, 2011.
  1. Jan 17, 2011 at 8:29 AM
    navyrt
    navyrt [OP] ROLL TIDE ROLL!!!!!!!!!
    Would like to see a few photos of how a bed topper attaches to a 2nd gen Tacoma with the bed rail system.. Im looking to get a used one but theres no attachment hardware. Any info/advice would help greatly!
  2. Jan 17, 2011 at 8:34 AM
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    a block that fits in the rail system that is threaded the a bolt through the topper. Ill take a pic later
  3. Jan 17, 2011 at 8:39 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The hardware would be easy to come by, at least for an ARE shell. You'd need 4 square nuts to fit in the bed rail system and 4 bolts for the attachment. The ARE shells have a lip that hangs over the bed sides that's drilled to allow the bolt to pass through and thread into the nut in the bed rail system. I'll try to get some pics up later today. What kind of shell is it that you're looking to buy?
  4. Jan 17, 2011 at 8:46 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Here's how my Leer was installed:
  5. Jan 17, 2011 at 8:48 AM
    j83soldier
    joshua
    Colorado
    05 tacoma
    never mind, there it is ^^^
  6. Jan 17, 2011 at 9:08 AM
    Pugga
    Massachusetts
    ARE is a little different, the bolt goes horizontal. There are fiberglass tabs that fold down over the bed rail and the bolt goes through that. You can still use the bed rails between the shell attachment points.
  7. Jan 17, 2011 at 9:42 AM
    navyrt
    Its an ARE.
  8. Jan 17, 2011 at 9:48 AM
    navyrt
    I know that this isnt on a 2nd gen, but if the bed dimensions are the same, it should fit right?? Owner told me it was 60"w x 63"L outside edges. I measured the L on my short bed and its approx 63"L. Has anyone attempted to put a later 1st gen on a 2nd gen?
    This is the topper Ive been asking/talking about. Thanks!!!!!!!!!!!!!!
  9. Jan 17, 2011 at 11:36 AM
    Pugga
    Massachusetts
    It might be worth calling your local cap dealer and asking about the differences. If you look at ARE's or Leer's websites the caps are split up by body style which would lead me to believe there's a reason or change in design. The physical dimensions of the bed may be close but maybe the cab has changed. Caps these days are made to follow the lines of the truck. If you mix and match, it might just be an asthetics issue or you could end up with a cap that rubs the cab. If your local dealer is any good, they should at least talk to you on the phone. Also, not sure how first gen caps attach to the bed. Worst case, go for a test fit and see how it looks and how you can make it attach.
    Edit: Here is how an ARE attaches to a 2nd Gen using the bed rails.
