Pics of trucks with just leveling kit lifts and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeffro9475, Feb 6, 2015.
  1. Feb 6, 2015 at 10:45 AM
    jeffro9475
    jeffro9475 [OP] Active Member
    Jeff
    Delaware
    2013 trd
    none yet.
    I will be putting a small leveling kit on my 13 trd soon just to get a little bigger tires on it for looks and driving on the beach and looking for pics of other nice trucks with the same...
  2. Feb 6, 2015 at 1:20 PM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    5100s to level the front. 265/75/16.
    Lowcountrytaco likes this.
  3. Feb 6, 2015 at 4:27 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    Very nice, did you just put the leveling kit on the front end or did you get a higher one that required the blocks under the rear leafs.
  4. Feb 6, 2015 at 4:32 PM
    Pigpen
    Dan
    Northwest Montana
    leveling means no rear lift. Anything higher than .85 on 5100s is a lift.
  5. Feb 6, 2015 at 5:37 PM
    Gimmick
    Anthony
    Canada
    Just bilstein 5100s in the front.
  6. Feb 6, 2015 at 6:06 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    Okay I completely understand, what are bilstein 5100s, I am assuming they are a brand name of the front end strut spacer but has to make sure I am new to the Toyota world I am reformed from a jeep lol.
  7. Feb 6, 2015 at 6:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    welcome young padowan. Your wallet hates you already.... if you are smart you delete this website from memory and go on with your life.
    5100's are front shocks made by bilstein that have 4 levels of spring preload adjustment... 0 .85 1.75 and 2.5in of lift.
  8. Feb 6, 2015 at 6:36 PM
    Va Bowhunter
    Va Bowhunter Well-Known Member
    Shawn
    VA
    05 Tacoma TRD
    ABS winch bumper, 8,500 smitty built winch
    since i just bought my truck a few weeks ago and that i have never owned a Toyota.
    i have no idea if my truck has a leveling kit or not.
    but it appears to set level and there is a good deal of room between the tires and the wheel wells. the name bilstein is on the front shocks. is this factory??
  9. Feb 8, 2015 at 12:55 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    All very good information. Really like this forum getting a lot of good feed back from people.
  10. Feb 8, 2015 at 1:05 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    So with the 3 inch lift and rear to level to match what would anyone recommend lt286/65r18 or 265/70r17
    I am leaning toward the 285 with these rims, my truck is the dark gray. Back space is 5 with the 6 5.5 lug pattern also posting to make sure I am heading in the right direction.
    MAGNETICGREYDESTROYER likes this.
  11. Feb 9, 2015 at 8:28 AM
    CpuPirate
    CpuPirate Active Member
    Wilson, NC
    2014 MGM DBSB TRD/OR
    It took all of 2 days for you to go from new tires and a leveling kit to new 33" tires and rims and a 3" lift ... This site will get to anyone.
  12. Feb 9, 2015 at 9:16 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    He's probably comparing supercharger prices as we speak. TW strikes again.
  13. Feb 9, 2015 at 3:35 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    I actually was already looking into the 3" lift with more in the front obviously to level it out so thought that was still considered a leveling kit. I have had 2 jeeps that were already lifted with 33's just looking to do this one myself from start to finish so new to it. Might go alittle bit smaller of a tire not sure, don't want to lift it that much and put small tires on it and have not look good. But anyway the way you put things it sounds a lot better and funnier by far.... Keep em comin the force is strong in this one...
  14. Feb 9, 2015 at 4:16 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Renaming the site - Ta put my wallet in a coma World.
  15. Feb 9, 2015 at 4:19 PM
    reasonselzzz
    reasonselzzz TAMU '18ish
    Reason
    Temple, TX
    2010 PreRunner 1981 Pickup
    I thought 1.75 was level
  16. Feb 9, 2015 at 5:20 PM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    Yeah well if I am going to own it and drive it might as well like it and have fun with it, can't take the money with ya when ya go lol....
    McConnellHand and LowFourJoe like this.
  17. Feb 9, 2015 at 5:47 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    2005 tacoma offroad 4x4, Bilstein 5100 front and rear, front set to 0.85" with stock off road coils, standard 3 leaf Toyota in rear. 265/75/16 Cooper ATP.
    tinker_troy and glwood6 like this.
  18. Feb 9, 2015 at 5:53 PM
    NPK.VTA
    NPK.VTA Member
    This is exactly what I want to do. Upgrade the shocks, raise the front a little and get a slightly bigger tire. Looks perfect. No rubbing issues, right?
  19. Feb 9, 2015 at 5:56 PM
    jmg256
    Al Tonter
    TRD Offroad
    Zero rub
  20. Feb 10, 2015 at 8:44 AM
    jeffro9475
    Jeff
    Delaware
    2013 trd
    none yet.
    Very nice truck, I am torn with lifting 3 inches or just leveling and going with new wheels and just a little bigger tire.
