Pics of what you tow with you 2.7
Discussion in '4 Cylinder' started by maxpower29, Mar 10, 2011.
  1. Jholden
    Jholden Well-Known Member
    That seadoo makes the taco look pretty small hah
  2. Warhawk
    Warhawk Active Member
    Hot Springs, Arkansas
    2010 Access Cab lowboy
    I finally have something to tow with my Taco. Just bought this boat, a Stratos 176 XT. My Taco has the 2.7 and automatic, I just put it in 3rd and it tows the boat fine. A little sluggish getting up to speed unless you keep the rpms up, but once I got it up to 65, I set the cruise and you hardly know it's back there.
    The place I bought the bought says it weighs about 2100 pounds, that's boat/motor/trailer. I don't know for sure, I couldn't get anyone at Stratos to call me back to confirm.
    Now if it would just warm up a little so I can put it in the water!
    Stopped on teh access road in front of Texas Motor Speedway on the way home.
  3. Jholden
    ^^^ Did you have a tranny cooler or plan on installing one?
  4. tacomawv
    tacomawv tacomawv
    Richard
    WV
    sr5
    Wade sure-fit mats, afe dry filter
    X2 on the cooler. Great looking boat. Good luck fishing.
  5. Warhawk
    Not yet, just had to get the boat home.
    But I do plan on adding a tranny cooler, any suggestions on which one?
  6. Warhawk
    I've towed the boat a few times now, back and forth to the lake only. I'm running in 3rd gear (4 spd automatic) and limiting myself to 65 mph, for the gas mileage as much as anything. I still need to get an tranny cooler.
    No problems at all towing, one ramp I used is extremely steep and the Taco pulled the boat up that super steep ramp with no problems at all. The only problem is have is that the trailer tires track is wider than the truck, and I have to really pay attention to not run it off the road, hit curbs, etc.
  7. eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '11 4x4 acc cab SR5
    Not much weight, only about 400 lbs, but I brought this tank home in the bed of the truck.
    And they said it wouldn't fit!
    It fit......sort of.
  8. Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    Lots of good coolers out there that will do you a good job. I've installed several on both tow vehicles and race cars, and my personal favorite is the B&M SuperCooler. They come in several different models. I usually get the version that has screwed fittings and then use braided hose with AN fittings for a surefire, leak-free set up. Some will think that is overkill, but it works well for me.
  9. hickorylarge
    hickorylarge Well-Known Member
    Sean
    Chester Springs, Pa
    Tacoma 2.7L
    I'm looking to tow a small camper with my 2.7. The one I'm looking at weighs 1100 lbs. Do I really need a tranny cooler? If so, how much do you think it will run with labor? My truck is brand new and still under warranty, is that something I should have done by the dealer?
  10. mistahgood
    mistahgood Active Member
    Mistah
    South Carolina
    2013 Tacoma Access Cab 2wd 4cyl
    I have the same setup as Warhawk.. 2.7L Access Cab 2wd. Its a 2013 with 4,000 miles on it so far, I also would like to know about how much it would cost with parts and labor to have it put on. Would a Toyota garage put it on?
  11. maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Wish I could help you. All I know is I would be getting one anyways to be sure. I hauled my tent trailer thats not much heavier then that and it does make the little 2.7 work and I even have the 5 speed
  12. Warhawk
    I had the local transmission shop put the cooler on mine. Cost was about $200.
  13. hickorylarge
    Sean
    Chester Springs, Pa
    Tacoma 2.7L
    $200 is not bad, I can swing that. I really don't want to have it done by the dealer, Im sure that will be a major rip off. Anyone have any idea if having it installed at a transmission shop will affect my warranty?
  14. The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I installed a B&M super cooler on a fox mustang I used to drive. Pretty simple to install on that car, but I have never looked at how much clearance ect. we have. I plumbed it to where it went through the cooler built into the radiator then through the B&M and back to the tranny.
  15. Warhawk
    I towed this rig about 100 miles yesterday, I filled up today to see what kind of mileage I got. 19.8 mpg towing, not too bad. Just about exactly what my 1984 2wd pickup did towing a UHaul trailer across country when I was in the Air Force.
  16. Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Wow I don't even get 19 in the city. Nice!
  17. Warhawk
    I run up and down the highway a lot in this one. I'd been getting 24-25 mpg, but lately I've used 100% gasoline and am up around 26 mpg. That's mostly running 70-75 on the interstate.
  18. Gus 524
    Justin
    MN
    Glade to hear the big numbers. Way to go!
  19. sabre19
    sabre19 Member
    Burlington VT
    2011 i4 Auto SR5 4x4
    GROM-USB2 w/ iPod and BT interface, OEM hitch and trailer harness, OEM tube steps, AFE Pro Dry S
    I towed a friend's 3-cyl diesel Kibota lawn tractor from his house to the repair shop yesterday, about 14 miles of steep hills and winding roads. The tractor weighs about 1400 lbs, the trailer I think about 500. I noticed it was back there when going up the steeper hills, but it wasn't a difficult tow.
  20. district 5
    district 5 Well-Known Member
    Del
    Honolulu, Hawaii
    13 Reg. Cab
    half of nothing
    when I had my 5 lug.:)
