Pics of what you tow with you 2.7
Discussion in '4 Cylinder' started by maxpower29, Mar 10, 2011.
  1. May 25, 2013 at 12:50 AM
    #161
    linzy77
    linzy77 Does not suffer fools lightly
    Linzy
    Dumbfukistan
    2013 Access V6 TRD Off Road
    From Florida to Seattle and back again. Then to hell and back (a couple times).
  2. May 25, 2013 at 12:55 AM
    #162
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    East Texas
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
  3. May 25, 2013 at 1:00 AM
    #163
    092wdtaco
    092wdtaco Active Member
    Charlie
    Bend, Oregon
    2009 2WD Tacoma Access Cab
  4. May 25, 2013 at 1:10 AM
    #164
    linzy77
    Linzy
    Dumbfukistan
    It was a 6x12 Uhual. Biggest they have. Tell them you have a V6 or they wont rent it to you. I had the bed full as well. I have no idea what the weight was but I am sure I was over. I-84 was SUPER sketchy. Going up hills was a chore and down was white knuckles. I recommend not going too heavy. Besides that it wasn't too bad just a bit slow. That was about 5 years ago. Had to add a leaf and replace the shocks a year after that but I was also playing in the Oregon Mts. Just traded her in 3 days ago and upped to a V6 TRD with Tow Pkg.
    Make sure you get a good service before you go and if you have an automatic I would absolutely get the tranny fluids changed out b4.
    Good Luck to you!
  5. May 25, 2013 at 5:29 AM
    #165
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    With my 285s and 3" lift I still haul these around without hardly noticing them. White and black KFX is about 400lbs and the Blue Yamaha is about 550-600lbs
  6. May 25, 2013 at 5:36 AM
    #166
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    With lift and aggressive tires I hauled 3600 pounds of demolished shed and trailer to the dump, I wouldn't want to do it all the time that's for sure. Normally I only tow my seadoo and Atv.
  7. May 26, 2013 at 11:59 AM
    #167
    092wdtaco
    Charlie
    Bend, Oregon
    Thank you for the info. I had planned on doing a thorough service before leaving. I went to Uhaul's website and they showed that I wasn't able to rent the 6x12 and was wondering how I was going to manage...now I know! I plan on moving as light as possible but that isn't very easy when it's cross country! ;) Congrats on the new truck by the way! Looks great!
  8. May 26, 2013 at 3:56 PM
    #168
    linzy77
    Linzy
    Dumbfukistan
    Thanks :thumbsup: I am excited to start my build! I was living in Bend also when I moved. (Small world) Good Luck on the move. I love Western NC and Eastern TN. Its beautiful country with lots of places to check out. Enjoy!
  9. May 27, 2013 at 3:20 PM
    #169
    btipsword
    btipsword Well-Known Member
    Ben
    Illinois
    12' Reg. Cab 4x4
    Billys at 1.75,1" Block in rear for now,16x8 Pro Comp 7089,265/75/16 Duratracs,Aftermarket Tow Hitch, Tint 30% front 2 15% rear
    Not a very good pic but hauled this refrigerator and my 12' brute force 750 about 10 miles.. let's just say it wasn't very aerodynamic. 4th gear was my friend. [​IMG]
  10. Jun 1, 2013 at 3:04 PM
    #170
    maxpower29
    Jordan
    Nova Scotia, Canada
    Towed this like a champ. Could barley notice anything was there
  11. Jun 4, 2013 at 1:49 PM
    #171
    yesmar
    yesmar Well-Known Member
    Harrisburg, PA
    13 Reg 2.7 4x4 5speed
    hey guys, I have to pull a 3700lbs car up a slight hill about a block or so. The car will be in neutral and has steering(someone will be in the car to operate the hand brake and control the steering wheel) I have 13 4cyl reg cab 4x4, think its worth a shot ? or do I have to swallow my pride and get a buddy with a more powerful truck to help.
    thanks for the advice
  12. Jun 4, 2013 at 3:28 PM
    #172
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I guess you'll be using tow straps?
    It should do it without an issue. You'll be needing to go pretty slow anyway since you're not using a tow dolly, and you don't want that car slamming into you.
  13. Jun 4, 2013 at 4:30 PM
    #173
    yesmar
    Harrisburg, PA
    yeah I plan on being in 4x4 maybe even low. yes someone will be in the car to use the brake pedal and ebrake when needed. the car is all wheel drive so all 4 will be on the ground rolling
    heres where it gets a little hairy, I don't have a tow package so my options are a ball on bumper(rated to 3500) or I can pull it up in reverse with the front recovery point. what do you guys think is my best option?
  14. Jun 4, 2013 at 6:53 PM
    #174
    2007 tacoma
    2007 Access Cab
    Here is someone that's pulled a car (although a lighter car) and trailer with theirs no problems. I doubt you'll need 4 low though that's an option if it comes to it.
    I've also pulled about that much weight with mine and it was fine.
    Not having a hitch makes it a different situation. I'm not sure I'd trust this to the bumper. Here's some other reading:
    http://www.tacomaworld.com/forum/off-roading-trails/138114-front-recovery-points.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/238133-recovery-points.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/121338-recovery-tow-anchor-points.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/110394-rear-recovery-points.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/64628-recovery-points.html
    It sounds as though your best bet may be using the driver's side recovery point in reverse with a tow strap and taking it a little slow.
  15. Jun 4, 2013 at 9:30 PM
    #175
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I towed that trailer and bug off of my bumper... Not saying it was the correct way to do it, but it got the job done. The truck had no problems pulling the car about 10 miles and backing up a driveway. I have a bumper mounted receiver hitch for easy connection. I'd say as long as you take it easy, you'll be fine with a strap off of the bumper. I don't see the need for 4x4 or 4 low, just drive it easy and feather the clutch. I personally would not tow something like that in reverse for that far, seems like a good way to tear something up. But what do I know, I'm just a guy on the Internet.
  16. Jun 5, 2013 at 9:35 AM
    #176
    yesmar
    Harrisburg, PA
    I appreciate it guys, I'm going to give it a whirl in the next day or 2 I'll post a pic later
  17. Jun 5, 2013 at 3:29 PM
    #177
    yesmar
    Harrisburg, PA
    ok gang I got it done! so relieved, I didn't get any pics in the midst of it the last thing on my mind.
    anyway to paint the picture
    threads in the head are also stripped
    We pushed it into work couldn't fix it there. First time it road piggy back in 4+ daily abused faithful years.
    This is where he left it. after I had a month or 2 to cool off I bought a REAL daily driver(Tacoma:) I need to get the off the street to swap parts with my other car and pull the engine and finalybuild it and go stage 3!
    to get it off the street I coast it further down the street to the level ground tow strap to a ball on the bumper 4wheel drive and pulled it all the way up 2 blocks and coast it down the street and up into the drive way where the old Mercedes is
    boom!
    :) now I can start wrenchin!
    my little 4cyl took it like a champ!
  18. Jun 5, 2013 at 3:31 PM
    #178
    Boone
    Boone Vaginas are rad.
    Boone, NC
    '12 DCLB MGM Sport 4x4
    K&N, charcoal filter delete, ABS kill switch, YWM. 5100's @2.5'', Progressive AAL, Wet Okole Covers, Weather Tech Liners, 285/75/16 KM2's, FJ Anthracite Trail Teams, MGM HLM...
    not mine, saw it in town a few days ago.
  19. Jun 5, 2013 at 4:32 PM
    #179
    2007 tacoma
    2007 Access Cab
    Ah cool. I didn't realize the bumper was that durable.
    I'm glad you were able to get it. Sorry to read about your Audi. I hope you get it going and are happy with it.
  20. Jun 5, 2013 at 5:09 PM
    #180
    yesmar
    Harrisburg, PA
    Thanks! The bumper is very legit. I was planing on doing this, then read a ton of post about"I would never pull/tow with the bumper"ect. Before I even posted here. That got me all paranoid so had to ask you guys. When I Looked at my bumper and see what mybumper took today. I think it's just tow package buyers remorse. I mean under the plastic it's a no sh!t thick steel plate bolted to both frame ends. I mean if your under 3800lbs I don't see the need. Except height adjustment
    And thank you the Audi will run... Much faster then before. I just want some parts off it to make it to waterfest next month with my other. B5 s4 is my passion :)
