*Picture* Leaky Rear Differential.......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShiftGear, Jul 22, 2010.
  1. Jul 22, 2010 at 11:52 AM
    ShiftGear
    ShiftGear [OP] Well-Known Member
    BC
    TRD Sport
    I have a 2010 Tacoma with 19,000 kms. I've gone through 2 oil changes, havn't done any preformance mods, no lift, tires, nothing. Almost all stock.
    I got curious when I read about frame rust issues so I looked under the truck. This is what I saw:
    * I dont have a digital camera on me, so I found a picture online that looks exactly like my rear diff, same type of leak, same issue*
    Mine is a little worse though, since I can see some spray of "oil" on the gas tank and a little on the drive shaft. This isn't normal or is it? I'm taking it to Toyota next week but I thought I would get an opinion from you guys? What causes this?
  2. Jul 22, 2010 at 11:54 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The seal needs replaced. Spray of oil on the gas tank? That sounds more like excess grease in the zerks and u-joints.
  3. Jul 22, 2010 at 11:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Times two.
  4. Jul 22, 2010 at 12:06 PM
    ShiftGear
    BC
    TRD Sport
    Hmm ok, how does this happen though? I guess I just want to know how I can prevent this from happening in the future?
  5. Jul 22, 2010 at 12:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its just a thin spot in the seal. No biggie. Get the seal replaced, and it may never happen again.
  6. Jul 22, 2010 at 12:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Did you check to see if the 3rd member is properly torqued to the axle housing? There have been numerous threads where members have experienced leaks just like you have and the nuts that secure the 3rd member to the axle housing have become loosened. If they are loose, be sure you use the proper torque sequence and specifications when tightening the 3rd back up.
    EDIT: I just noticed you have a bran new truck. I wouldn't even mess with it. Take it to the dealer and have them deal with the problem.
  7. Jul 22, 2010 at 12:10 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Actually need to see a picture to diagnose it. But, if you look directly above the u-joints and see a line/splatter of grease that is perpendicular to the drive shaft, then it is from the grease in the u-joints. It is ok. It is just excess gress being expelled from the joint.
    The diff leaking like that is one of two things: the seal was f-ed up when it was installed or the diff nuts weren't torqued properly.
  8. Jul 22, 2010 at 12:13 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I like this:
    And if you wheel - check the torque of those bolts on a semi-regular basis.
  9. Jul 22, 2010 at 12:14 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    My rear diff looks exactly like this. Toyota said it was normal and the fluid was full. I don't believe them, but it is documented if something happens later.
  10. Jul 22, 2010 at 12:16 PM
    HBMurphy
    Paul
    So California Coast
    None
    There is some truth to this. As long as you check the level every blue moon you will be okay. If you like to tow or wheel... check more often.
  11. Jul 22, 2010 at 1:56 PM
    rumrunner358
    rumrunner358 Member
    spray on the fuel tank and bed is probably a leaky pinion seal. what you have is really nothing big, more like a seep then a leak.
  12. Aug 7, 2010 at 3:35 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 Access Cab 4x4, 17 TRD Sport 6 MT
    Leer 100R
    Would anyone happen to have the torque sequence / specs for this? Just noticed I have the same seepage on mine, and have apparently misplaced my repair manual...
  13. Aug 7, 2010 at 4:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FSM states 18 lf-lbs.
  14. Aug 7, 2010 at 4:34 PM
    TroutBum
    Michigan
    Leer 100R
    Thanks Chris!
  15. Aug 7, 2010 at 8:38 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack
    If I were the technician working on your truck, I'd clean it then ask you to return. Leaks dont usually occur on top of or side of the diff; most of the time its on the bottom. I would also check to torque.
    There is a possibility that is could be leaking, but cleaning it first with brake clean and re-checking is the best thing to do.
  16. Aug 8, 2010 at 5:16 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I vote for your answer. It's logical.
  17. Aug 8, 2010 at 7:58 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    And why is this a big issue?
    Do nothing except take it in to the dealer since you should still be under warranty! Like someone else said they'll prolly just check torque and tell you it's normal. Which it may not be but so what since it's really hard to see what bad can happen with just a tiny seepage like that pic shows. You're far more likely to have far worse problems if you let them try to replace the gasket material.
    Also, it can't be 'oil spray' you're seeing, not from that. The differential doesn't use pressure-fed oiling and the housing isn't under pressure. I go with the slinging from grease in the u-joint but on the outside chance it's oil from the pinion seal then that IS a problem that should be dealt with...under warranty!
    Actually...just had a second idea...could be a plugged up differential housing breather: that would pressurize the housing as it heats up, blowing oil past the seal and gaskets which aren't designed to handle it.
  18. Aug 8, 2010 at 10:03 AM
    HBMurphy
    Paul
    So California Coast
    None
    Very good answer!!! Nice!
    EDIT: I HATE stealer installed problems!!
  19. Aug 16, 2010 at 9:44 PM
    BIG MoFukin SERG
    BIG MoFukin SERG Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    x2
    I had a similar Diff leak with my 2009...took it to the dealer and they took care of the issue at no cost...the diff bolts weren't torqued to spec...but don't touch it cuz it will void the warranty since they mark all the bolts...take it in and if you're as lucky as I was, theyll even wash your truck for free. :D
  20. Aug 16, 2010 at 9:48 PM
    HBMurphy
    Paul
    So California Coast
    None
    Just used this stuff again last Wednesday - I love this stuff! :)
    Pun optional. :)
