Picture of my 2017 Limited Tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SWB Tacoma, Apr 24, 2017.
  1. Apr 25, 2017 at 10:08 PM
    SWB Tacoma
    SWB Tacoma [OP] Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I tried programming the opener again. No go. Do a little more research.
  2. Apr 25, 2017 at 10:10 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    :cheers:
    Congratulations!
  3. Apr 26, 2017 at 4:36 PM
    SWB Tacoma
    Arkansas
    I got opener in truck programmed to open garage door. It is a Genie opener. Thought I would past instructions.
    HOMELINK IN-CAR REMOTE PROGRAMMING INSTRUCTIONS
    To program a built-in-car transmitter to a rolling code garage door opener (Genie rolling code is called Intellicode, Liftmaster/Sears is called Security plus), you should take the following steps.
    1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
    2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
    3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
    Programming a Fixed-Code Device (Majority of units made prior to 1996)
    These devices have internal dip-switches located near the battery of your remote.
    1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute. (In most cases, the key should be on auxilary, and/or the car door must be shut).
    2. Press and hold the in-car button you want to use to operate your garage door while simultaneously pressing and holding the button to your hand held remote until the LED on the in-car remote flashes rapidly.
    3. Test the in-car remote by pressing the button you chose to operate your door.
    4. When the door operates your in-car remote is programmed
    Krogen, TeecoTaco and over60 like this.
  4. Apr 26, 2017 at 5:22 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Google it for instructions from the Homelink website. Call their 1-800 help line at a last resort. I was able to find the correct directions via Google.
  5. Apr 27, 2017 at 9:31 PM
    83Toy4x4
    83Toy4x4 Member
    1983 Toyota 4x4
    3 inch lift, 33 bfgoodrich all terrain ko2, with 450,000 k miles and still going
    Hello everyone, there's some, I guess bad news, there's is going to be a recall on some 2016 and 17 Tacoma's, something about the rear diff. leaking oil, just be patient and wait for the letter from Toyota, good luck to everybody
    RIDERED67 likes this.
  6. Apr 27, 2017 at 10:27 PM
    hellaflushca
    hellaflushca @truck_norriz
    My truck looked like this for 2 weeks.. then the modding began... and now im broke.
    openspace4x4 likes this.
  7. May 22, 2017 at 9:26 PM
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    Thank YOU! I've been wrestling with Homelink in my GT350. Ford's instructions are pathetic and worst of all they don't work. I followed your instructions and voila! it works for Fords too! Now before y'all accuse me of being a Ford guy, I do have a Tacoma; it just doesn't have Homelink.
  8. May 22, 2017 at 10:48 PM
    Rowdymoon
    Rowdymoon Well-Known Member
    Courtice Ontario
    2017 Inferno OR SB Canada
    6112's and 5160's
  9. May 29, 2017 at 2:57 PM
    TacoMacMD
    TacoMacMD Well-Known Member
    Mac
    Chandler, AZ
    2016 Toyota Tacoma BBP Limited DCSB
    Thank you so much! This worked like a charm. :dancingbacon: Other instructions I found said to do EITHER step 2 or step 3 but not both.
  10. May 29, 2017 at 7:20 PM
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
  11. May 29, 2017 at 7:23 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    The Sr5 and Limited have always shared the same grille/surround. I don't know why Toyota didnt just go with one standard grill with different surrounds like before. Eh. I like my cheese grater.
  12. May 29, 2017 at 7:23 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Yanno, I sub'd this thread for the homelink programming doc, then you drop in a very nice pic...its like the cherry topping...very nicely done
  13. May 29, 2017 at 7:25 PM
    ZachMX
    Congrats OP, they aren't as bad as everyone makes them out to be, 6 tacoma and by far my favorite.
  14. Jul 29, 2017 at 10:08 AM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    The sr5 grill is more black where the limited is like a dark grey
  15. Jul 29, 2017 at 10:09 AM
    #35
    Canadianguy91
    Sean
    2016 Limited
    How does it look now?
  16. Jul 29, 2017 at 5:29 PM
    #36
    SWB Tacoma
    Arkansas
    I'm glad they didn't.
    mbarbay likes this.
  17. Jul 29, 2017 at 5:35 PM
    #37
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    So the limited comes with 18" wheels? Sweet, very nice
  18. Jul 29, 2017 at 5:46 PM
    #38
    SWB Tacoma
    Arkansas
    Yes.
  19. Jul 29, 2017 at 9:10 PM
    #39
    kgb136
    kgb136 Member/ReMember
    Brian
    San Diego
    2016 Limited BBP 2007 TRDOR Indigo Ink Blue
    AMP Research Power Running Boards, Un-Holy phone mount
    I bought the limited so I wouldn't have a chrome grill. To me it looks like a cheese grater.
    mbarbay and Canadianguy91 like this.
  20. Jul 31, 2017 at 2:47 PM
    #40
    hellaflushca
