Picture: Will 33's fit
Discussion in '1st Gen. Tacomas (1995-2004)' started by You, Dec 17, 2009.
  1. Dec 17, 2009 at 2:57 PM
    You
    You [OP] Junior Mint
    Right now I have 32x11.50-15, 10" wide rims and 3" body lift. It rubs a tiny bit when turning and slightly compressed. I would like to put 33x12.5. Will Bilstein 5100 leveling struts allow this to happen?
  2. Dec 17, 2009 at 3:04 PM
    smuook
    smuook Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
  3. Dec 17, 2009 at 3:05 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    33s will barely fit and still likely rub... you would want a full 3" of suspension lift to keep the sidewalls aways from the frame and stock UCA...
  4. Dec 17, 2009 at 3:06 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    although, if running 15s, you likely have 3.75" backspace so you might actually fit...
  5. Dec 17, 2009 at 3:45 PM
    kg4ghn
    kg4ghn Well-Known Member
    GA
    13 PreRunner TRD Sport
    A guy I work with has 33x12.50r15s with a 3 inch body lift and a spacer lift. He has a 2000 extended cab.
    He has no rubbing at all, his wheels do stick out a pretty good bit. The 15 inch wheels do make a difference because of the backspacing.
  6. Dec 17, 2009 at 4:31 PM
    You
    Do you know what size spacer he has?
    The tires already stick out a good bit, but i kinda like it like that. To me it looks pretty cool right now, but I need new tires and 33's do not cost that much more. I wonder if it would be overkill with even bigger tires. This is not for offroad use, "Mall crawler" as they say. Maybe some very light trails once or twice a year.
    Any more information would be greatly appreciated.
