Pictures of 5100's installed on my 2012 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinclm, Apr 17, 2012.
  1. Apr 17, 2012 at 7:25 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    Set at .85" ride is great. next is some new tires...not sure what kind or size. I'd like a nice stance and look. Thinking of going with an all terrain an inch or so bigger and wider. what do you guys suggest? I'd also like to keep my odometer accurate, is it worth getting it recalibrated?
  2. Apr 17, 2012 at 7:57 AM
    ee1284
    ee1284 Well-Known Member
    Louisiana
    05 Prerunner Sport
    Truck looks good. Love the 2012s
  3. Apr 17, 2012 at 8:02 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    I love my 265/75 Duratracs. I'll let you take a ride in the truck if we both go to a meet over the summer!
  4. Apr 17, 2012 at 8:34 AM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    It looks like you got as much lift at 0.85" as I did setting mine at 1.75". Interesting. Truck looks great by the way.
  5. Apr 17, 2012 at 8:47 AM
    dustinclm
    Thibodaux, La
    had duratracs on my 1st gen, i dont need anything that heavy or aggressive even though i liked them a lot. these duratracs have to go because i slide everywhere but im liking the 19-21 mpg so i may stick with the same size all terrains
    my rear wheel wells were 1.25" to 1.5" higher than my front so .85" was perfect for me. i have heard different model tacomas will need different heights to be level so that may be why. That or the 1" is harder to see because of the pictures
    im also thinking of taking my step bars off, they came with the truck but i dont use them, my g/f who is 5'8" doesnt use them either. they look good but are just kind of useless.
  6. Apr 17, 2012 at 10:33 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    I'd say the general grabber AT2's in your case
  7. Apr 17, 2012 at 11:10 AM
    dustinclm
    Thibodaux, La
    my buddy just put those on his truck and they look pretty good. ill look into those
  8. Apr 17, 2012 at 11:21 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I didn't think you could get the Odometer re-calibrated. Can anyone confirm this?
  9. Apr 17, 2012 at 1:14 PM
    TRDfarmerTN
    TRDfarmerTN Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    truck looks great!! consider some toyo AT's..even in a P series tire if u dont offroad..i put P series toyo at on my 08' put 27k on them now there on my 12' taco with 5k and still half tread!! didnt loose any MPG cause there not a heavy load tire
  10. Apr 17, 2012 at 1:20 PM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    I didn't get mine recalibrated but my gps and odometer are both spot on even with my 265/75 duratracs
  11. Apr 17, 2012 at 1:35 PM
    dustinclm
    Thibodaux, La
  12. Apr 17, 2012 at 2:05 PM
    ItalynStylion
    Steven
    DFW, Tx.
    That's because they weren't before. ;)
