Pictures of Rust on '03 Tacoma- Need diagnosis
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yamasaki, May 4, 2010.
  1. May 4, 2010 at 7:22 PM
    Yamasaki
    Yamasaki [OP] Yamaha + Kawasaki!
    Denver, CO
    2003 Tacoma Limited TRD 4x4
    Ok I snapped a couple pictures of the underside of my '03 Tacoma. Pretty rusty down there. Vehicle grew up and spent 7 years in Vermont. The truck goes in for the dealer inspection on Friday. Issue is I am taking vehicle to Toyota dealer in Denver who has seen very few of these frame rust issues.
    On the bottom of the frame rail, there appears to be indentations every foot or so on both rails. I have taken pictures of 2 different indentations. I am wondering if anyone can tell me if these indentations are built into the design of the frame or if it could be a rust through. Seems as though I could see up inside the frame if I scraped away all the rust but I'm hesitant to do so before the inspection.
    I appreciate the help!
    Picture one is just a pic of overall condition of frame, but it has worse rust around forward suspension. Its dark, pics are hard to take. Pic 2 & 3 show different pics of these indentations.
    Also, I have stuck my finger inside of several of the drain holes in the frame and there is all sorts of flakey mess inside there...
  2. May 4, 2010 at 7:30 PM
    Thomas The Train
    Thomas The Train Well-Known Member
    Thomas
    LA
    00 Prerunner
    Fenders, 32s, headlights, intake, sound system
    Not sure if this will help but one of my coworkers had a 2000 tacoma in which his frame rusted. Dealer looked at it and they paid him the value of the truck when it was sold brand new off the lot.
  3. May 4, 2010 at 7:33 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    i hope its not as bad as the pictures look. but if it is, you may be getting a new frame friend :)
  4. May 4, 2010 at 7:36 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    the 01-04's dont get that deal, they either get a protective coating if it passes. But If not they replace the frame completely. I would take it in and have then do a frame test, and see if it passes. But I dont think it will. that looks pretty bad man!
  5. May 4, 2010 at 7:37 PM
    Yamasaki
    Denver, CO
    Well to be honest, I'd rather just have frame replaced. Rest of truck is in great condition. If it does have rot and they end up buying it back, I'd just go out and look for a new '01-'04 Tacoma in good shape.
    If no rot, I am going to have a long day of wire wheeling, priming and painting the frame. Should be fun. I will let you all know the results of Friday's test.
    If anyone else has any insight on wether or not those are frame indentations that would also be great.
  6. May 4, 2010 at 7:45 PM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    My 03 has the same holes/indentions, no clue what they are though. My frame looked pretty similar to yours when I took it in. I passed and got the frame coating. When I got my truck back they told me that I was on the verge of failing, whatever that means. All of my suspension components are rusted, as well as the rear axle. I'll have trouble removing any bolts should I need to.
  7. May 4, 2010 at 7:57 PM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    The indents are meant to be there. I would say they are there for fitment of the sections for welding the boxed frame rails.
  8. May 4, 2010 at 8:17 PM
    shift96
    shift96 Well-Known Member
    didn't you just buy this? If it was this bad I would not have bought it. Seems it would have been a hell of alot easier to just keep shopping and find one with no rust:confused:
  9. May 4, 2010 at 10:28 PM
    Yamasaki
    Denver, CO
    Meh.. I got a great deal on it. Everything else is in great shape. If the frame is bad, I get a new one. If not, I sand it and make it look pretty.
  10. May 5, 2010 at 12:55 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    They will either replace the frame or give you a good bit of money for it.
  11. May 5, 2010 at 5:06 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Why? If the body is in good shape and the frame fails inspection, he will basically have a new truck when they get done with it. The fact that he got a good deal on it makes it that much sweeter.
  12. May 5, 2010 at 6:33 AM
    shift96
    I would just rather not have a frame replaced if I didn't have to. That is a MAJOR job to do a frame swap. Judging from the dealers I have been to I would not be too confident that they would get it just like a factory assembled truck. Probably wrong but I would just shop for another one with no rust and leave the headache and dealer dealings to someone else. Good luck with the truck though, sounds like you did get a good deal.
  13. May 5, 2010 at 6:36 AM
    shift96
    The frame is pretty important. Would you buy a house with a rotted foundation because the vinyl siding was new? Plus who the hell has the time or the ambition to sand the frame and paint it. :D Good luck though. Sounds like you have the time and the ambition!
    Oh and I'm really not trying to piss in your corn flakes. I guess I should have not even posted. Good luck man!
  14. May 5, 2010 at 8:48 AM
    Yamasaki
    Denver, CO
    In the Denver area, I Tacoma in decent shape with realtivly low miles can run from $13k to $15k. I picked up this baby for $9.5k. I know a rusty frame can be an issue, but I have an extra car and bought this truck mostly because anyone who owns a house knows how handy a truck can be.
    Plus, I have enough free time where I can sand and paint the frame if I need to. I used to work on my cars in college all the time (I was broke and it was my only option) and I enjoy it.
    We will see what happens :eek: :)
  15. May 5, 2010 at 11:06 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    If the third picture is a actual hole THROUGH the frame, it will fail automatically by the rule book. But otherwise it looks fine, they rust from the inside. The outside won't look bad and it still can fail. Make sure they do the hammer test for strength when you take it in. I wouldn't waste time sanding and smearing shit all over on the outside, that's not the issue. If you do the inside frame rails, you're golden.
  16. May 5, 2010 at 11:18 AM
    Yamasaki
    Denver, CO
    It would be more of an aesthetics fix if the truck passes. paint the rails and clear the rust off the rear diff will make it look alot better.
    I read online @ Edmunds that Toyota could also fail the frame if it has an unusually large amount of surface rust and no perforations in the frame...
  17. May 5, 2010 at 12:08 PM
    brg88tx
    brg88tx Well-Known Member
    wow, it's amazing what that road salt does to vehicles. my 03 deep south owned prerunner doesn't even have any surface rust at all.
  18. May 5, 2010 at 12:19 PM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    My neighbor had a 2002 Tacoma with extensive frame rust.... He had over 120K on the odometer when he received a letter from Toyota asking him to take in his truck for inspection. Inspection failed and Toyota offered him a check for $14K and an incentive if he bought a new Toyota. He ended up getting a new 2009 Tacoma and just a few weeks later he received another check for $6K. Amazing if you asked me! I have a 2003 Tacoma and no frame rust...
  19. May 5, 2010 at 3:02 PM
    dip
    dip Member
    NE Ohio
    01 Tacoma
    My frame replacement has not gone well. Trip number 3 back to the dealer tomorrow. Electrical issues now...
  20. May 5, 2010 at 3:17 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    i have an 03 i have never checked for rust on the frame. it still looks good. would i get a new frame if the rust gets bad?
