Pictures of Sliders Bolted to the frame.
Discussion in 'General Automotive' started by luk8272, Apr 23, 2010.
  1. Apr 23, 2010 at 11:13 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have searched and ended up makeing a thread, sorry.
    I have a set of bolt on sliders that I have still not installed. They are weld on and I will be heading to Arkansas in 2 weeks, so 1 side will be welded on and the other bolted due to the fact that I have some exhisting body damage and will need to be able to remove the slider to repair it.
    I am thinking about just welding some angle iron to the slider then bolting that to the frame.
    I'd like to see what some of ya'll have.
  2. Apr 23, 2010 at 2:15 PM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
    don't have any good pics, but here's a couple:
    Demello Hybrids
  3. Apr 23, 2010 at 2:33 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Thanks for the pics they are just fine. I hadn't thought about bolting from the bottom along with the side. About how far from the pinch weld are the legs? I am thinking of trying to get about a half inch. Would that have enough allowance for when they are put to use?
  4. Apr 25, 2010 at 1:49 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    What size bolts are being used?
