PID00 ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Aug 25, 2020.
  1. Aug 25, 2020 at 3:22 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Check Engine - Scangage says PID00 - Googled it came up with nothing - YouTube came up with nothing. 2008 2.7 Tacoma. Any help or links appreciated.
  2. Aug 25, 2020 at 3:28 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Almost sounds like a setting for custom PID00. 00 being the location; up to however many you can program into the unit.
    TnShooter likes this.
  3. Aug 25, 2020 at 3:32 PM
    george3
    New Jersey
    Thanks for the reply - I apologize but I have no idea what U R talking about - I thought these were codes telling you to fix something and the code would tell you what it was needed fixing.
  4. Aug 25, 2020 at 3:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you have access to a different scan tool, try it.
    It doesn’t sound like the ScanGage is reading the code correctly?
    Jimmyh likes this.
  5. Aug 25, 2020 at 3:38 PM
    george3
    New Jersey
    Thanks - I'll see if Advance or a local parts store can scan if for me. Good suggestion.
    TnShooter[QUOTED] likes this.
  6. Aug 25, 2020 at 4:14 PM
    Larzzzz
    Larry
    MA
    A code generally starts with a letter and 4 numbers.
    For example: P0420 is a code relating to catalytic converter efficiency. P refers to the power train module. The numbers.... sequential...I dunno.
