Pie pan syndrome.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustdevil, Nov 11, 2015.
  1. Nov 11, 2015 at 11:39 PM
    Dustdevil
    Dustdevil [OP] Member
    don
    Tacoma SR5 4x4
    Yesterday I bought a very nice 2006 Tacoma 4 cylinder, 5 speed manual transmission, standard cab 4x4. It wasn't until today I noticed a noise I can only describe as an aluminum pie pan being dragged behind the truck. It only happens at high speed in 5th gear when I decelerate, it's not very loud and only lasts for maybe 2 seconds. There's no vibration associated and I've checked for anything loose (exhaust, frame, ect, ect). The U-joints seem tight but will probably replace as it has 125,000 miles. This noise is definitely coming from the rear of the truck. Any of you guys encountered this problem...???
    Oh - and thanks for adding me to the group..
  2. Nov 11, 2015 at 11:46 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Have a gopro u can mount under truck for help?
  3. Nov 12, 2015 at 12:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    " It only happens at high speed in 5th gear when I decelerate"
    Sounds like a heat shield for the exhaust is vibrating...
  4. Nov 12, 2015 at 10:56 AM
    Dustdevil
    don
    Tacoma SR5 4x4
    I've checked the heat shields and pretty much eliminated any other sources of vibration. I'm reasonably sure that it's more mechanical. I'll have the u-joints replaced as I did notice a clanking noise this morning. Looks like it's going to be a process of elimination. Thanks fellas.
  5. Nov 12, 2015 at 10:58 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Bad catalytic converter.
    Bet me.
    tomwil likes this.
  6. Nov 12, 2015 at 11:32 AM
    Dustdevil
    don
    Tacoma SR5 4x4
    That is a possibility. I bought a new Tacoma in 97 - used and abused it for 18 years and it never made a noise like this. Thanks for the tip.
  7. Nov 12, 2015 at 11:36 AM
    T4RFTMFW
    My first cat failed at 12k miles (2.7..). I hear occasional rattle noises now at 38k miles while accelerating but they're not anything unusual yet.
    There is a new TSB on catalytic converters released from Toyota, so I'd call your dealer and see if you qualify for a replacement.
    Another member on here has less miles than I do and is on his third catalytic converter.
  8. Nov 12, 2015 at 11:39 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Would that not rob him of power under acceleration though? The last cat that went out on me in my Jeep, it didn't matter how much skinny pedal I gave it, the darn thing wouldn't move.
    (insert jeep joke here)
  9. Nov 12, 2015 at 11:40 AM
    T4RFTMFW
    I didn't have any issues with power when mine failed. It just rattled obscenely because the internal structure failed. I didn't have a check engine light, and I didn't have any codes thrown either.
  10. Nov 12, 2015 at 11:40 AM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I also have a slight rattle, and have always thought it was a heat shield somewhere. I'm at 140,xxx
  11. Nov 12, 2015 at 11:41 AM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Now you guys have me thinking as well.
  12. Nov 12, 2015 at 11:42 AM
    T4RFTMFW
    Less likely to be a cat with your V6, but since OP has a 2.7 and they're having horrendous amounts of catalytic converter failures for some time now, and now with the recent TSB confirming that there is a known issue - that's where I'd bet my money if all other obvious signs of rattle have been checked.
  13. Nov 12, 2015 at 11:44 AM
    NmBeefTaco
    NmBeefTaco Well-Known Member
    Greg
    New Mexico
    18 TRD Off Road Access Cab
    Toytec Boss lift, AAL, Ride rite air bags, Daystar cradles, Total Chaos UCA, Icon 17 inch Rebounds, 285/70R17 BFG KO2s, Ruff country 30” LED light bar kit, ruff country tri fold bed cover. Interior LED lighting and lic./reverse LED lights.
    Dealer called today and said my parts are in for my new catylytic converter. Not a moment too soon. I'm tired of people looking at me when I rattle and jingle by.
    T4RFTMFW likes this.
  14. Nov 12, 2015 at 2:07 PM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    This.
  15. Nov 12, 2015 at 6:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Not a TSB.
    It is a Special Service Campaign SSC and not limited by miles or years.
  16. Nov 12, 2015 at 6:13 PM
    T4RFTMFW
    Even better. Thanks for the correction Jimmy!
  17. Nov 12, 2015 at 6:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  18. Nov 12, 2015 at 10:14 PM
    Dustdevil
    don
    Tacoma SR5 4x4
    I have no codes or lights either. Is there a funky-ass smell associated with a bad c/c.?? I pulled over on my way home tonight and I sure have one. I'll be headin' to the dealer tomorrow to see about replacement regardless.
  19. Nov 12, 2015 at 10:22 PM
    Sccafire
    Sccafire KMG 365
    Cleburne, Texas
    2023 Jeep Gladiator Rubicon
    Smell like rotten eggs? if so then most likely its a cat
  20. Nov 12, 2015 at 10:30 PM
    T4RFTMFW
    There can be a smell. I didn't have one.
    I really had no sign of a bad cat except the rattling noise. All the "signs" weren't there.
