Piece of junk
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vicseb, Apr 25, 2024.
  1. Apr 26, 2024 at 8:19 PM
    #221
    Aaron O.
    Aaron O. Well-Known Member
    Aaron
    Denver, CO
    2023 Tacoma Off Road DCLB
    Just checking in. Is this still the cat thread because cats are great!
    Barsoom, Junkhead, E3g and 2 others like this.
  2. Apr 26, 2024 at 8:20 PM
    #222
    Plus20DB
    Plus20DB Member
    The Burgh
    19 Barcelona Red SR5 DCSB
    I just wear the same racing helmet that I use to drive when I'm in the garage now. You guys do the same thing, right?
  3. Apr 26, 2024 at 8:34 PM
    #223
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
  4. Apr 26, 2024 at 8:37 PM
    #224
    Nevada Mike
    Nevada Mike Well-Known Member
    Michael
    2022 Silver Tacoma TRD Off Road
    It could be worse; you could have bought a ram. Your complaints are minor compared to the problems you would have faced with a ram.
    petethemeat and SGJarrod like this.
  5. Apr 26, 2024 at 9:16 PM
    #225
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    Well, since you said cats are great this kitten is for you.
  6. Apr 26, 2024 at 9:35 PM
    #226
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
  7. Apr 26, 2024 at 9:40 PM
    #227
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Im getting allergies acting-up in here!
  8. Apr 27, 2024 at 2:37 AM
    #228
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    :cheers:
    All threads are potential cat threads.... you just have to put the work into it :rofl:
  9. Apr 27, 2024 at 5:45 AM
    #229
    Mikeymopar
    Mikeymopar Active Member
    2023 Tacoma Trail Special Edition
    huh...I must be incredibly lucky. I sold my '94 Ram at 240K when I bought my '03 Ram which I just sold at 295K downgrading to the 2023 Taco in October. Following a regimented maintenance schedule I never had a single engine/trans issue nor any oil leaks. Did need to rebuild the half shaft in the '03 and replace the fuel pump. Wheel bearings and many u-joints in both. My '02 Ram 2500 (pictured in the What's Your Other Vehicle thread here) has 160K hard miles on it as I use it to plow our mile long dirt road to our house. I guess pretty lucky again since it's still original untouched engine and trans after all these years pushing a 1000lb snow plow and 40+ feet of snow in the winters (tho it did have a real easy winter this past one, only got about 18 feet). Did just replace the bed because it was about to fall off and rebuild the half shaft in this one too. Proper maintenance and care go a long way. I've always believed that Toyota guys, no matter the generation, maintain their vehicles better than most hence the better track record in the longevity department.
    And I apologize for the long winded off topic post in my rebuttal to the couple of posts with such vitriol towards non-Toyota vehicles. In the handful of forums that I skim through, this one ranks number one in projective identification. Must be an age thing.
  10. Apr 27, 2024 at 6:05 AM
    #230
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Ggot a good point. Ever triied to stuff a child in their "extended cab"
    E3g likes this.
  11. Apr 27, 2024 at 6:19 AM
    #231
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I haven't gotten them to fall for my tricks yet. Trying puppies next.
    Barsoom, mtip and wilcam47 like this.
  12. Apr 27, 2024 at 6:23 AM
    #232
    Nevada Mike
    Michael
    You must have gotten lucky. Mine was in the shop every 30K miles for exhaust manifold replacement under warranty. Last year the rear end was replaced under warranty. This last time ram cancelled my warranty and walked away from it because they didn’t want to spend the money to replace the motor after the lifters seized taking out the camshafts and the rest of the motor. That leaves me with a truck wit a little over 120K on it that doesn’t run. It was always properly maintained and I used Pennzoil Ultra platinum synthetic oil as recommended by the manufacturer. Blackstone labs analyzed the oil from every oil change showing everything was fine until the last oil change. I did the last oil change before I started noticed the ticking from the engine. That oil change showed a problem. As soon as it started ticking I took it in to be fixed. The dealer determined it was the camshaft and submitted a claim to ram. It then took ram 6 weeks to approve the first bit of work to be done. By the time ram stopped work on it 5 months had lapsed. When I first dropped it off, it was 1 of 3 trucks at this small dealership with the same problem. One of the service advisors told me they had several trucks there with different issues that had been there for 10 months. No confidence in that brand or any other brand that is made by stelantis.
  13. Apr 27, 2024 at 6:24 AM
    #233
    Nevada Mike
    Michael
    I wouldn’t try to put a child in any of there vehicles. I don’t trust their vehicles enough to put a child in one.
  14. Apr 27, 2024 at 6:35 AM
    #234
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Compared to my 3 (new) Dodge service vehicles and one personal (bought new) Ram 1500 you were incredibly lucky. 3 tows to to the dealer where they finally resolve electrical problems that required a new ECU, 1 new cyl head (4 weeks in the shop), a plastic intake manifold, out of balance ring gear causing a rear end rebuild at 40Kmiles on a babied truck and the scary death wobbles at very inopportune times. Dodge was the biggest POS truck I've ever owned, they might be better now I'll never buy another.
  15. Apr 27, 2024 at 7:00 AM
    #235
    OverlandMark
    OverlandMark Active Member
    2023 tacoma TRD sport
    LOL... I have a Porsche 914/6 and most peeps think it's a Miata.
    But this comes back to the point of if you come from small car ownership the Tacoma is huge, but on the other hand if you're coming from owning a full size pickup or SUV likely you'll find the interior quite small.
    Barsoom likes this.
  16. Apr 27, 2024 at 7:15 AM
    #236
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  17. Apr 27, 2024 at 7:53 AM
    #237
    SGJarrod
    SGJarrod Jester of the Degen...
    STL
    23 TRD OR DCLB, Blue Crush
    I got a sticker and some cool valve stem caps...
    Dodge/Ram/Chrysler = Electrical Gremlins
  18. Apr 27, 2024 at 7:56 AM
    #238
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    FIAT = Futile Italian Attempt at Transportation
    Nevada Mike and 71tattooguy like this.
  19. Apr 27, 2024 at 7:59 AM
    #239
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Fix It Again Tony :rofl::rofl: And I’m Italian
    MGMDesertTaco likes this.
  20. Apr 27, 2024 at 8:11 AM
    #240
    eladmit
    eladmit Well-Known Member
    2007 Silver TRD Offroad
    I bought a new 2023, and I must admit it has been disappointing with multiple problems from bad paint to warped drums. All have been fixed except for a torque converter shudder that it is at the dealer now for. If they can remedy that I'll keep the truck, but I have a feeling they are going to say it's normal or just a characteristic of these trucks. If that's the case, I'll be selling or trading it. Life is too short to keep a vehicle you are not happy with. My 2007 Tacoma was awesome, drove it for 16 years.
