Pigtail Connector Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, May 28, 2023.
  1. May 31, 2023 at 4:03 PM
    #41
    Pittsy
    Pittsy [OP] Ex car guy, currently in rehab
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Do you have any ideas for the two separate IGN 12V Sources and the one constant source?
  2. May 31, 2023 at 4:19 PM
    #42
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The constant power source I would run directly to the battery or underhood fuse box (be sure to put a fuse in it within a few inches of the battery).
    For switched ignition you can use E8 Pin 9 (Orange), it's powered by the IGN fuse (15A) (Hot in Run & Start).
  3. May 31, 2023 at 4:23 PM
    #43
    Pittsy
    AZ
    Gotcha, I'll do that for the power wire. For the switched wires, it's asking for two separate sources, could I just run a one way diode on each of the leads and run them to the same source?
    Holley is concerned about the transmission back feeding the ecu and keeping the engine running even with the ignition turned off.
    Let me know what you find out about the fuel pump.
  4. May 31, 2023 at 4:26 PM
    #44
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I didn't see where it said that but I'll have to look again later.
    Are you wanting to use the factory pump and wiring?
  5. May 31, 2023 at 4:29 PM
    #45
    Pittsy
    AZ
    I think a 12v diode should solve that problem.
    I have an DW340 pump installed in the oem bucket. If the factory wiring can still run the pump then great, if not ill have use the holley output wire to trigger the fuel pump relay.
  6. May 31, 2023 at 4:32 PM
    #46
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can use the factory wire to the tank but the C/OPN Relay is ground side switched, the Holly system is switching the power side.
  7. May 31, 2023 at 4:34 PM
    #47
    Pittsy
    AZ
    What power wire goes to the tank? pump?
  8. May 31, 2023 at 4:40 PM
    #48
    Pittsy
    AZ
    The DW300 (340LPH) pulls 14.4 amps @80PSI. Holley's manual states that no relay is needed for anything less than 15 amps. So, I could wire the pump directly to this green wire as long as you can tell me which wire actually goes back to the tank from the engine bay.
  9. May 31, 2023 at 6:12 PM
    #49
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    15 amps may be pushing it for the stock wire, I'm not sure what gauge it is but I don't imagine it's any bigger than 14 gauge.
  10. May 31, 2023 at 6:57 PM
    #50
    Pittsy
    AZ
    We’re you able to find what wire it was?
  11. May 31, 2023 at 8:54 PM
    #51
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The easiest place to tie into it would be the Black/Red wire at the Fuel Pump Resistor or Pin 4 of the Fuel Pump Relay socket.
  12. May 31, 2023 at 8:55 PM
    #52
    Pittsy
    AZ
    I’ll try to find out what size wire it is
  13. May 31, 2023 at 8:56 PM
    #53
    Dm93
    Texas
    2014 DC OR 6spd 4x4
  14. May 31, 2023 at 9:04 PM
    #54
    Pittsy
    AZ
    14 gauge is rated to 15 amps as well, so looks like it’ll be fine even worst case. I bet you it’s 12 gauge. But I’ll find out tomorrow for sure.
  15. Jun 1, 2023 at 9:53 AM
    #55
    Pittsy
    AZ
    Best place to access that wire? Coming out of the fuse box?
  16. Jun 1, 2023 at 9:55 AM
    #56
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    At the fuel pump resistor.
  17. Jun 1, 2023 at 9:55 AM
    #57
    Pittsy
    AZ
    Where’s that located at?
  18. Jun 1, 2023 at 10:01 AM
    #58
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Right in front of the battery.
  19. Jun 1, 2023 at 10:02 AM
    #59
    Pittsy
    AZ
    Do all trucks come with this? I’m not sure that I have that.
  20. Jun 1, 2023 at 10:03 AM
    #60
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    All V6 Tacomas 05-15 have it.
