Pillar installed!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2.7taco, Aug 9, 2010.
  1. Aug 9, 2010 at 5:30 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I only have one picture its not the best.
    Anyone know what color rattle can or paint to use to match the color better. And how do I make the handle corner fit more flush?
    The trans. mod I did and the reason for the trans. temp gauge.
    The spring shim for the accumulator. There are two shims only took a picture of one.
    The accumulators in the trans. case. The shims goes in the larger two accumulators. You can see the accumulator sticking out that has the shim installed.
    Basically it speeds up shifting. The ones I had built was only .310" thick and just polished up the shift points. They could have been thicker and given me an even faster shift but it was experimental.
  2. Aug 9, 2010 at 5:40 PM
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    looks good ive been debating getting a pillar with the aeroforce gage and tighten the screw in the oh shit handle some more and it might tighten up the corner a bit not sure tho
  3. Aug 9, 2010 at 5:59 PM
    2.7taco
    Texas
    All the rest of it seems to fit good its just the corners and those oh shit handles are tight believe me.:D
  4. Aug 9, 2010 at 6:26 PM
    2.7taco
    Texas
    Any guesses on how to get a better fit on the oh shite handle?
