Pillar vibration with crosswind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma2g, Jun 24, 2019.
  1. Jun 24, 2019 at 4:37 AM
    tacoma2g
    tacoma2g [OP] Well-Known Member
    Midwest Ohio
    2015 DCSB
    This sound is killing me! It happens to both sides from the outside if there's a strong crosswind. When driving 60MPH, it's almost a guarantee. If I pinch the door to the frame, it goes away sometimes. Has anyone fixed this problem? I can't find much online.
    A video recorded while driving is here: https://www.dropbox.com/s/qxtk1f2mvhrncrv/IMG_2140.mov?dl=0
  2. Jun 24, 2019 at 5:01 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    Turn your radio on...loud! :thumbsup:
    Seriously, it's only wind noise. Check the weather stripping in that area to make sure it is OK and then readjust the door hinge to close a little tighter.
  3. Jun 24, 2019 at 5:32 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Pop off those 2 plastic square covers on the grab handle and see if you can tightened the pillar bolts. You can add more thickness to the OEM weatherstripping around that area with a layer or two of double sided foam tape.
  4. Jun 24, 2019 at 6:47 AM
    Taco-mama
    2015 DCSB Prerunner
