pilot on gas fireplace.
Discussion in 'Off-Topic Discussion' started by coffeesnob, Mar 25, 2011.
  1. Mar 25, 2011 at 1:46 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    My tank is 60% full. Valve on the tank is open. Valve going to the burner is open. When I try and start the pilot light (method is correct) I get the little spark but pilot won't light and I do not have a trace smell of any propane. Any ideas. What is a thermopile? Thanks
  2. Mar 25, 2011 at 4:01 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    Are you able to access the burner? Has the unit been unused for awhile? Sometimes the holes in the burner can be obstructed with corrosion and need to be cleaned. This can be done with a wooden toothpick acting as an awl but before you do anything, turn the propane off and be sure the system is empty!!
  3. Mar 25, 2011 at 4:03 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Windham Maine
    09 TRD SPORT
    TRD Short Throw, TRD Exhaust, 5100 1.5, Weathertech floor liners, AFE Filter, Projector Head and fogs, Weathertech vent visors
    sometimes if the valve on the burner is open when you open the tank it activates a safety on the tank and does not turn on..
  4. Mar 25, 2011 at 4:07 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    A thermopile, or thermocouple, sends a mili-volt signal back to the valve to signal the pilot is lit. The signal is generated from the heat of the flame via to dissimilar metals.
  5. Mar 25, 2011 at 4:13 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    try bleeding the line. (safely) if your not smelling gas, then your not getting gas. you depending on how old the unit is, you may need to clean the pilot assembly. thermocoupler is the copper coated line that is coming from your gas valve (inside the unit) to the pilot assembly. we normally clean ours with sos pad, or fine sand paper. if you clean it make sure your gas is off obviously.
    if your not sure what the hell your doing, have a service guy come look at it.
  6. Mar 25, 2011 at 4:18 PM
    squad314
    Marc
    Good advice if you are not 100%.
  7. Mar 25, 2011 at 4:24 PM
    coffeesnob
    VA
    I just bought the house and I think the original owners left the pilot light on most of the time. When I looked at the house the thing worked great, everytime I flipped the switch the fireplace lit up right now. Then when those owners were moving out they turned everything off. The unit is 5 years old. I think someone said to turn the valve off under the burner before I turn the propane tank valve on I haven't tried that I think on my gas grill if you turn the burners on before you turn on the tank they will not light even after shutting them off and turning them back on.
  8. Mar 25, 2011 at 4:30 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If it's been awhile since you used it, or changed tanks, you may not be waiting long enough for the gas to get from the valve to the pilot burner. If that's not the case, either you have a blockage, or the regulator is hosed. The pilot should always work regardless of the thermocouple, it just won't stay lit if it's bad.
    This is assuming you're running a vent free burner from a propane tank.
  9. Mar 25, 2011 at 4:52 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    dam did you swallow an encyclopedia:crapstorm:
    :thumbsup:
  10. Mar 25, 2011 at 5:24 PM
    coffeesnob
    VA
    gas had plenty of time to get to the burner. I believe this is a vented system
  11. Mar 25, 2011 at 5:25 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, I'm a sponge.
  12. Mar 25, 2011 at 7:04 PM
    Superx2
    Joey
    Iowa
    can you smell gas yet? does it have a union? is it gas pipe or gas tite? sounds like a gas issue. what kind is it? pic?
  13. Mar 25, 2011 at 7:24 PM
    brianh
    brianh Active Member
    Brian
    Shelby, N.C.
    06 Trd Sport , radiant red 4x4, sr5, 4.0 v6,
    Compustar remote start/alarm system, Infinity componets up front, JVC 3 ways in the back, 5" tvs in the headrests, JVC nav/dvd/i pod/ sd/ usb,back up camera (flush mounted in rear bumper), rear aux back up lights, LED bed lights, bestop camper cover, garage door remote operated by cig. lighter, katzkin leather kit(Ice Gray) with heated seats up front, (door panels too) All Mods installed by myself.
    They way to tell if it is a vented fireplace is if there is glass on the front of it.(an enclosed combustion chamber) This type fireplace will also be vented out a wall or the roof to a cap. If you have a spark and no ignition you probably have air in your line. At 60% LP in the tank you are 80% full on gas. Try to use a aim a flame grill lighter as you are holding in on the gas valve. That will speed up the bleeding of the line. You may have to break the flex underneth the unit to break the air lock on the valve. If it is a vent free unit you will have nothing or just a screen in front of the unit. In this case as sson as you smell gas you should have the air out.
  14. Mar 26, 2011 at 5:08 AM
    coffeesnob
    VA
    Yes it does have the glass surround. I have a hunch you are correct about an air lock.
