Pin hole in my radiator help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cookee62, Dec 22, 2011.
  1. Dec 22, 2011 at 12:20 PM
    cookee62
    cookee62 [OP] Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    Ok so I'm out in central Florida and go off roading quite a bit. I haul ass and do about 30-50 mph and take small jumps and stuff. This is my second radiator that is leaking. I have a skid plate (stock) and have bull bar as well not the one that bolts on all the way on the bottom like a Westin. Mine bolts near the bottom and through the grill.... Please help I don't know why I keep doing this. How can I get this to stop happening. Should I weld a crash guard? Buy a heavy duty radiator? Please help especially u Baja guys thanks
  2. Dec 22, 2011 at 1:08 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    is it just possible your having bad luck?.......or are you actually getting debri up in it to cause the pin hole?
  3. Dec 22, 2011 at 1:09 PM
    Aw9d
    Aw9d That one guy
    Az
    Where is it leaking from?
  4. Dec 22, 2011 at 3:59 PM
    cookee62
    Lake Mary, FL
    06 DBL Cab
    Well I can't really tell its not overheating but the drips of water are from the passenger side bottom corner
  5. Dec 27, 2011 at 4:57 AM
    cookee62
    Lake Mary, FL
    06 DBL Cab
  6. Dec 27, 2011 at 4:59 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    your probably putting a lot of stress on the radiator while "hauling ass and takin small jumps and stuff" which is causing the radiator to crack
  7. Dec 27, 2011 at 6:06 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have not been jumping or off roading lately, but during my last maintenance routine I found my radiator real loose, (no work every done to lead to this?) and thought if I had been doing any off roading lately what damage may have developed? These trucks are abused by many on this site without reported radiator issues, so it could be as mentioned bad luck or?
  8. Dec 27, 2011 at 9:16 PM
    Detective_Dan
    Colorado Springs
    first off, you cant really state that "these trucks are abused by many" because i know of more people that baby their trucks rather than destroying them. i personally wouldnt abuse a $30k truck and i dont think anybody else will either. second off, radiators are made of very thin, shitty alloys or very thin copper. it doesnt take much to crack a radiator. im a generator mechanic in the air force and i see cracked/leaking radiators weekly
  9. Dec 27, 2011 at 9:23 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Only radiator problem I have had is when I left a wrench sitting on the engine and closed the hood. Left the neighborhood and the fan sent the wrench through the radiator. :anonymous:
