PINCH WELD CUTTING AND WELDING 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacolover15, Jun 4, 2019.
  1. Jun 4, 2019 at 6:31 PM
    Tacolover15
    Tacolover15 [OP] New Member
    Logan
    2004 Tacoma 2.5" lift
    I have beat my pinch weld flat and tires rub full crank and full turn, and suggestions on grinding the pinch weld back and welding a beed
  2. Jun 4, 2019 at 7:38 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Er...is there a question in this?
  3. Jun 4, 2019 at 9:16 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    gunna need more info here... Like your tires, wheels, lift, *where* it's rubbing, etc...
    Area51Runner likes this.
  4. Jun 5, 2019 at 12:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    His question is will grinding and tacking the pinch weld flush fix his rubbing .
    We have no idea without lots more info !!
    Pictures would also be a big help
  5. Jun 5, 2019 at 1:25 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So here is what I have found -
    if you have aftermarket wheels or wheels from a diff gen taco (i.e. anything other than stock 4.5" backspace) and/or larger than stock tires (some with 265/75s encounter rubbing, anything larger is a definite)... then you WILL rub the frame at full lock - doesn't matter what you do.
    If rubbing the liner/back of the wheel well, then perhaps an alignment or aftermarket UCAs would help in addition to what you have already done with the pinchweld.
    More info needed.
  6. Jun 5, 2019 at 1:28 PM
    eon_blue
    Azusa, CA
    Need more info on your lift setup and tire size
    I got rid of my pinch weld rubbing by getting my caster pushed to 3 degrees by a competent alignment shop.
    But depending on your lift and tire size you might just need to be trimming even more.
    Wyoming09 likes this.
  7. Jun 5, 2019 at 2:33 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Wonder what Scuba's been up to after all these years?
