Pinch Weld on Cars
Discussion in 'Technical Chat' started by nammer, Mar 24, 2015.
  1. Mar 24, 2015 at 7:37 AM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hey, have a question for you guys, when jacking up by the pinch weld, what is actually the best way to do it, lift by the actual pinchweld itself, or the area surrounding it? I am thinking about getting one of these to use on my wife's car, didn't know which was the better idea, the deeper one, or the more shallower one, thanks!!
    http://www.ebay.com/itm/1-ea-Univer...hash=item35e42d7c92&item=231461452946&vxp=mtr
    http://www.ebay.com/itm/04-Subaru-W..._Automotive_Tools&hash=item4d21d4b3fc&vxp=mtr
  2. Mar 24, 2015 at 7:43 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I wouldn't do it with or without one of those. maybe its ok just not something I would do
  3. Mar 24, 2015 at 8:01 AM
    nammer
    Nam
    Bradenton, Florida
    what do you suggest? ive used my floor jack on pinch welds before and it has crumpled them
  4. Mar 24, 2015 at 8:04 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Not ideal, but in the past I've used a oak 4"x4"x7" block with a dado cut in it to not place pressure directly on the pinch weld. Works well for what it is.
  5. Mar 24, 2015 at 8:07 AM
    nammer
    Nam
    Bradenton, Florida
    so you'd think more of the pressure should be on the surrounding area and not on the pinch weld itself?
  6. Mar 24, 2015 at 8:14 AM
    Boone
    Boone, NC
    Airbags deployed
    Exactly, it's pretty much a wooden version of the jack pad in your original post. I wouldn't feel good about putting weight directly on the pinch weld. Ever.
  7. Mar 24, 2015 at 8:15 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    There should be a place or two on the pinch weld that is for jacking. Most of the time there are marks or notches. A good rule of thumb is to jack where there is vertical structure above it (behind the front wheel where the firewall floor and side join together)
  8. Mar 24, 2015 at 10:12 AM
    pudge151
    Sean
    Connecticut
    I always jack from the frame, or lower control arms or axel
  9. Mar 24, 2015 at 4:31 PM
    nammer
    Nam
    Bradenton, Florida
    cool thanks guys, i'm gonna go with the one with the deeper cut, i just took the factory jack and it doesn't actually lift from the pinch weld either, it uses the surrounding area around it
  10. Mar 24, 2015 at 4:32 PM
    nammer
    Nam
    Bradenton, Florida
    yea, i def do that with the taco, but can't with the car
