Ping after switch to synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spilser, Jun 30, 2016.
  1. Jul 5, 2016 at 7:46 AM
    #41
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    As quoted on "onpointdyno.com"
    Blow-By
    – An engine with poor crankcase ventilation will result in excessive blow-by, which will result in knock. As we mentioned earlier, oil lowers the effective octane of the fuel, so if the blow-by gasses cannot vent out of the crankcase they will re-enter the combustion chamber and reduce the effective octane.
    Additives like octane boosters, water injection or methanol injection can increase the effective octane of the fuel, while excessive oil in the inlet tract can reduce the effective octane of the fuel. For that reason it is very important to have an effective crankcase air-oil separator if the crankcase gasses are to be re-circulated back into the inlet tract
  2. Jul 5, 2016 at 12:56 PM
    #42
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    I concur Dr.Ethanol messes with everything.Need to get air/oil seperater soonish.But well maintained.
  3. Jul 5, 2016 at 1:20 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    On a 2013 I seriously doubt the PCV System is plugged.
    gonathan85 likes this.
  4. Jul 5, 2016 at 1:26 PM
    #44
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Changed my pcv this year 11 yrs old. Clean as a whistle.Spring tensions sure don't know.But engine runs like Hell like usual..
  5. Jul 5, 2016 at 5:07 PM
    #45
    Armkb
    09 TRD Sport DCLB
    Im not saying that there is something wrong with the PCV system...just that there seems to be some correlation between pinging and blow by gasses from synthetic oils and the tune of the later model Tacomas.
  6. Jul 5, 2016 at 5:19 PM
    #46
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My Tacoma needs 2000 rpm + under load, 1500-1700 rpm is too low.
