Pinging at acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Sep 10, 2019.
  1. Sep 10, 2019 at 3:27 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys need a little guidance. I have a 2011 with the 4.0 and auto trany. I am getting some pinging between 3 & 4 gear when accelerating. It doesn't do it all the time. Notice it mainly in the after noon with or with out the A/C. I am running Chevron fuel just regular unleaded. Anyone else have or have had this issue and what did you do to correct it? Any help is mu h appreciated! Thanks in advance!
  2. Sep 10, 2019 at 5:42 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Have you changed your spark plugs lately?
  3. Sep 10, 2019 at 5:49 PM
    tacoma guy
    Joe
    Phoenix Az.
    I did about 12000 miles ago.
  4. Sep 10, 2019 at 7:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Just out of curiosity?
    Did you replace them with iridium tip plugs?
  5. Sep 10, 2019 at 7:40 PM
    tacoma guy
    Joe
    Phoenix Az.
    No I replaced them with the stock Denso plugs that Chris 4x4 recamended in his write up.
    TnShooter[QUOTED] likes this.
  6. Sep 10, 2019 at 8:08 PM
    tacoma guy
    Joe
    Phoenix Az.
    I have always run Chevron and it's been fine. Thicking of trying a different fuel companie or even trying 91 octane?.
  7. Sep 10, 2019 at 8:16 PM
    TnShooter
    Deogee
    STOCK
    That’s definitely an easy option and test.
    It’s feasible that the fuel is the issue.
    Worth a shot, if it fixes the issue. You don’t have any time or parts invested.
    The 2012+ trucks did have an issue with pinging. The fix was an ECU reprogram.
    2011 and older did not have this TSB. I honestly do not know why the 2012+ even had an issue.
    I think they might have started the Air Injection Pump that year.
    Never the less, your truck isn’t one that should be affected by that issue.
  8. Sep 10, 2019 at 8:32 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    My truck pings under heavy acceleration (like if I floor it) basically every time, seems to do it regardless of fuel quality. Its always done it, with new plugs and old plugs. Dealer says the ECU reprogram has been done... I've just learned to live with it.
  9. Sep 11, 2019 at 4:48 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thanks for the replys. Yeah that's what I was thinking that I would try different fuel companies and even try 92 octane if needed...
    I had heard that the 2012 and up were having this issue but never really followed it to closely. I will keep trying different things and see what works. Thanks again guys !
  10. Sep 11, 2019 at 7:58 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
  11. Sep 11, 2019 at 8:46 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    2011 and under trucks still had pinging issues, but toyota didnt address it via ecu reprogramming due to it being out of a warranty window.
    The pining you hear wont cause problems, the truck will pull timing in that area automatically.
    2012+ trucks with the ecu reprogramming start low on timing and advance up till pining is "heard" by the knock sensors. 2011- trucks work the opposite, their timing starts out on that borderline of almost too much and retards down.
  12. Sep 11, 2019 at 9:37 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thank you for that. It gives me a better understanding of what is going on. So there really isn't any adjustment or anything that can be done to correct this issue on the 2011?
  13. Sep 11, 2019 at 9:40 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Try out some premium fuel (91+ octane) and that will help narrow down what the issue might be at least. If the pinging goes away then you know you're dealing with a lean/pre-detonation issue, if not then it's likely something else.
  14. Sep 11, 2019 at 9:46 AM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah for sure. I will give it a try. :thumbsup:
  15. Sep 11, 2019 at 9:47 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Run premium and ill bet the pinging goes away. Its an ecu issue. My 2013 did the same thing when it was hot out
  16. Sep 17, 2019 at 7:47 PM
    tacoma guy
    Joe
    Phoenix Az.
    I did notice if I pop it out of over drive it helps and even make the pinging go away.
