Pinging when accelerating, help please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by triplejjj, Dec 10, 2013.
  1. Nov 3, 2016 at 5:00 PM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have to go to the dealer and have them upload it. The ping reflash. There is an actual name for it. I just don't feel good enough to search for it. Plenty of other posts have been made about it.
    A few people have even done fuel pump ramp tests and found the factory unit to be inadequate/failing. So they upgraded theirs and it solved their issue.
  2. Nov 6, 2016 at 10:04 PM
    #62
    hueman562
    hueman562 Well-Known Member
    ken
    los angeles
    13 double cab LB 4x4
    I had that same problem. I took it to the dealership and they performed An Ecm reprogram. It got better. But still hear it sometimes. Hear it more with the 87 octane. Not so much with the 91. So I just use 91 now.
    10trdtaco likes this.
  3. Nov 7, 2016 at 4:41 AM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'd be curious what a ramp test, for your fuel pump, would show @hueman562 ?
  4. Nov 7, 2016 at 7:30 AM
    #64
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Mine tings or pings under a load as well, mostly under 3000 RPMs. Can sound really bad sometimes.
  5. Nov 7, 2016 at 9:17 AM
    #65
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    I'm trying premium shell octane, and running cleaner through the fuel! See if that fixes it, if not checking into TSB 0014-44 for the 12-15 models reprogramming ecm
  6. Nov 7, 2016 at 10:09 AM
    #66
    10trdtaco
    Shayne
    Lynchburg, VA
  7. Nov 7, 2016 at 10:11 AM
    #67
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How many miles does your engine have @10trdtaco ?
  8. Nov 7, 2016 at 10:11 AM
    #68
    10trdtaco
    Shayne
    Lynchburg, VA
    77k
  9. Nov 7, 2016 at 10:13 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depending on a list of variables, it could easily be that your fuel filter is just simply saturated with contaminants.
  10. Nov 7, 2016 at 10:20 AM
    #70
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    It's a 10:1 compression engine which is pretty high. Unless you're at elevation, 89 is too low regardless of what Toyota recommends IMHO.
    digitaLbraVo likes this.
  11. Nov 7, 2016 at 10:20 AM
    #71
    10trdtaco
    Shayne
    Lynchburg, VA
    How do I check that?
  12. Nov 7, 2016 at 10:21 AM
    #72
    10trdtaco
    Shayne
    Lynchburg, VA
    So use premium to be safe?
  13. Nov 7, 2016 at 10:21 AM
    #73
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Drop the tank and pull the filter
  14. Nov 7, 2016 at 10:25 AM
    #74
    10trdtaco
    Shayne
    Lynchburg, VA
    Dang. Have you done this? Rough or pretty simple?
  15. Nov 7, 2016 at 10:27 AM
    #75
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If going this far, just upgrade the fuel pump with a kit from URD. The OEM filter isn't exclusively replaceable. ~$450+ for the OEM replacement. The URD kit makes it a 5 minute replaceable filter, for the future PM. ~$160.
    10trdtaco[QUOTED] likes this.
  16. Nov 7, 2016 at 10:30 AM
    #76
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Not on this rig but on others.
  17. Nov 7, 2016 at 10:31 AM
    #77
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Yeah, this is a good idea
  18. Nov 7, 2016 at 10:37 AM
    #78
    BaconPower
    Portland, OR, USA
    Yes. High octane gases only exist to prevent high compression engines from pinging. That's the only reason high octane gas exists.
  19. Nov 7, 2016 at 10:41 AM
    #79
    Tylandus
    Tylandus Well-Known Member
    Midwest
    2019 4Runner SR5 Premium Superwhite
    The IT geek in me first thinks that your truck is sending an electronic message (a ping). Perhaps another descriptive verb is necessary?
  20. Nov 7, 2016 at 10:56 AM
    #80
    10trdtaco
    Shayne
    Lynchburg, VA
    I thought this kit was for forced induction Tacomas?? Or for both?
