Pinging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CJWinOR, Jul 28, 2019.
  1. Jul 28, 2019 at 11:30 AM
    CJWinOR
    CJWinOR [OP] Member
    Is pinging very common with these trucks? The first few months I owned my 2018 TRD Off Road, the engine did not ping. After about 6,000 miles it started pinging, almost knocking immediately after a downshift while going uphill. In time it started pinging but not as hard while going uphill before the downshift.
    Using higher grade gas helps but does not eliminate the problem. The dealer that has been servicing the truck has noted the pinging but has no idea what is causing it, or so they say. They suggested using better gas. In my area there is nothing better than Chevron Supreme which is 92 octane. I've been using Chevron Supreme in effort to minimize the pinging, but have also tried 76 and Costco with no changes noted.
    Do others have this issue? Has anyone been able to resolve it? I intend to take the truck to a different dealer but am fact gathering before doing so.
    rubiconjp, AKGSD and Vlady like this.
  2. Jul 28, 2019 at 11:34 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Pinging on any vehicle is not normal. Engines have knock sensors and can adjust themselves, for the most part, Pinging can be caused by heat as well. That is NOT normal. I would get it checked out and PRAY you don't hear "they all do that. It's a feature of the truck" Words I will never forget coming from the mouths of Toyota dealers.
    AKGSD, Chew, camillethetoy and 3 others like this.
  3. Jul 28, 2019 at 11:47 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Owner's manual, page 636:
    ■If your engine knocks ●Consult your Toyota dealer.
    ●You may occasionally notice light knocking for a short time while accelerating or driving uphill. This is normal and there is no need for concern.
    I'd increase RPMs.
    specter208 and AKGSD like this.
  4. Jul 28, 2019 at 11:55 AM
    TacoBella
    Tom
    Toyota favorite reply to issues......."This is normal. They all do it" Knocking and Pinging is not normal on any vehicle. Pre-ignition is not normal
  5. Jul 28, 2019 at 12:02 PM
    CJWinOR
    CJWinOR [OP] Member
    I'm aware that it isn't normal, I'm asking if other Tacoma owners are having this issue.
  6. Jul 28, 2019 at 12:08 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Not a common complaint.
  7. Jul 28, 2019 at 12:44 PM
    Paul631
    Thankfully this is not an issue on the 2TR, we're both enjoying our 4-cly midsized trucks :cheers:
  8. Jul 28, 2019 at 2:25 PM
    Ionnaeus
    Ionnaeus Well-Known Member
    Jon
    Tennessee
    2016 Quicksand SR5 DCSB
    Not to be confused with the "Taco tic. "
    MaTaco_4x4 and Taco_Craig like this.
  9. Jul 28, 2019 at 2:40 PM
    Jim1946
    Jim1946 2020 TRD Sport 4X4
    San Francisco Bay Area
    2020 TRD Sport 4X4
    Neither my 2016 nor my 2019 pings.
    Junkhead likes this.
  10. Jul 28, 2019 at 2:41 PM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Mine started around 8 -10k miles. Took it dealer, they couldn't duplicate as one would expect. Eventually went to 89 chevron and it helped. Now, when I see a hill put my hand on the shifter and if theres even a hint of clatter/pinging hit S4 and it drives like it should
  11. Jul 28, 2019 at 2:50 PM
    CJWinOR
    CJWinOR [OP] Member
    Nope, it isn't the assorted mechanical noises the engine has always made.
    Taco_Craig likes this.
  12. Jul 28, 2019 at 3:05 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Mine does it at low RPM, under load before downshifting. Using 91 octane seems to eliminate the problem.
    I've only used Shell/Chevron/Texico since it was new. I don't know what else to do except use 91 octane.
  13. Jul 29, 2019 at 12:08 PM
    LiplessSoul
    LiplessSoul Well-Known Member
    2017 Black Tacoma TRD Sport
    Pinging..... Hmmmmm
    I suspect that it is a Susuki/Tofu class sub on your six. Set your charges to 20, 35, 60 & 96.3 meters and proceed in a zig-zag pattern until the threat is destroyed or breaks off it's engagement. Godspeed!!!
    44-16 Taco, Rrowdy, Amanelot and 5 others like this.
  14. Jul 29, 2019 at 12:17 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    specter208, Azza, BillDaCat8 and 6 others like this.
  15. Jul 29, 2019 at 2:38 PM
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    Break the truck in.
  16. Jul 29, 2019 at 2:45 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    by putting it in the manual they made it normal
    dont even need to go to them to be told its normal
    :rofl:
    TacoBella[QUOTED] likes this.
  17. Jul 29, 2019 at 5:02 PM
    TacoBella
    Tom
    Who can blame them? They sell every Tacoma they make. they are definitely not the same company they were 10 years ago. With my first three Tacomas I never heard "they all do that" or "it's a characteristic of the truck" as much as I heard it on my 2016
  18. Jul 29, 2019 at 5:08 PM
    Joe23
    think how I feel.
    I'm waiting for toyota corporate to get back to me to decide if they will replace my steering rack thats already failing at 58 000km and they are blaming a 2" lift and 33" tires.
    Still within warranty and I got extended warranty for some stupid reason.
  19. Jul 29, 2019 at 5:57 PM
    TacoBella
    Tom
    That's why I am paying the dealer for a level lift. No issues with Radar....
    Man, I feel bad for you. maybe you can get the dealer to split the cost......I don't know what's going on with Toyota. They are killing it with sales........definitely a disconnect in the warranty services. The more they sell, the more possible warranty work. I can visualize backed up service appts.
    Joe23[QUOTED] and camillethetoy like this.
  20. Jul 29, 2019 at 6:29 PM
    Joe23
    It's funny you say that.
    I brought that up to them when they tried denying it with pointing to my lift and I said their dealer was selling lifted trucks
    We'll see what happens. Based on how they said the clunk is from where "the inner tie rod knuckle connects to the rack"
    Based on what I'm finding online a inner tie rod change will fix this. But I dunno if they mean it's the input knuckle. Time will tell. Clunk is only on the driver side which again seems like inner. And they're just saying rack because dealer stupidity. Haven't dug too into it. I originally brought it to the shop I deal with thinking it was as uniball but he said no that's definitely tie rod so went to dealer and here we are.
    If they don't warranty I'll be starting with inner and go from there. If that doesn't solve time to look into a Tundra retrofit or something stronger. If 3rd Gen can't handle a little abuse fuck factory rack
