Pinging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CJWinOR, Jul 28, 2019.
  1. Sep 11, 2019 at 11:42 AM
    #41
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    Apologies. I ass'med.
    Yeah, I've heard knock from HM vehicles, but not on EFIT engines that have all their sensors intact.
    If it's pinging, there should be a code indicating the affected cylinder(s). If the sensors are connected. At this point, my money is on the wiring. F'ing mice. Little bastards get into everything.
    auskip07[QUOTED] likes this.
  2. Sep 11, 2019 at 1:35 PM
    #42
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I would maybe try resetting the ECU.
  3. Sep 11, 2019 at 1:57 PM
    #43
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    My trucks been doing this since i noticed it around 20k or so....
    Just as you describe..
    High octane fuel helps, but doesn't eliminate it...
    Its always the same pattern... and always the same amount of ping... I'm racking it up to the way it works...
    I complained at the dealer... And a competent tech acknowledged the issue but even with the scan tool hooked up, he said everything was normal... And assured me if it was an issue, the engine light would be on...
    If you go on lexus forums, they complain about it too... And the lexus version always runs on 91...
    Let that knock sensor do its job, they are just trying to save you fuel...
  4. Sep 11, 2019 at 3:10 PM
    #44
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I just think this engine was intended to ping a bit. The logic in the ECU for knock feedback and timing control is essentially, "no knock, advance timing, no knock, advance timing, knock?, retard timing, repeat"
    If you watch the Knock F/B Value and Knock Correction Learn Value on a scan tool / OBD2 device you can better see what its doing. When you can actually hear audible ping, likely you'll have -6 to -8 Knock FB Value, and the ECU will constantly try to keep the FB Value to -3. As it gets below -3 (to -4,etc.,) you'll see it reduce timing realtime from those measures. Mine will stick to -3 most of the time, but during shift flaring there's occasional ping and sometimes under hard acceleration, rarely audible unless I'm in an area with high walls or a building on the sides of the truck to reflect the pinging back to me.
    Skydvrr likes this.
  5. Sep 11, 2019 at 3:17 PM
    #45
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    Mine does it.
  6. Sep 11, 2019 at 6:53 PM
    #46
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  7. Oct 3, 2019 at 12:55 PM
    #47
    Khakiman
    Khakiman Well-Known Member
    2017 Black Tacoma 4X4 Double Cab TRD Sport
    Front Grille, Step Bars, Tinted Windows, Tonneau Cover, Wheels, Tires, Roof Racks, Mud Flaps, Led Fog Lights, Mob Armor Phone Mount, Console Organizer, Pioneer AVIC 8200 NEX Radio/GPS,
    Having same issue. Just got tune up 62K miles. Technician says everything is fine no codes and engine to him sounds normal. I noticed it more starting around 52K miles. I guess I’ll just have to get used to it.
  8. Oct 3, 2019 at 1:29 PM
    #48
    slvrtaco11
    slvrtaco11 Well-Known Member
    SF bay area
    2018 TRD OFF ROAD AC
    tint, oem bed mat, CVC tune
    Octane 89 fixed my pinging. Was using 87.
    Crap gas in California!
  9. Oct 3, 2019 at 1:50 PM
    #49
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    The 4.0 is pretty noisy. I have an 05 Tundra with the 4.0 and it sounds like a diesel compared to the 3.5. Especially going uphill, the valve clatter gets louder but there is no harm done that I know of, it has 150k miles.
